spi clock problem
I'm trying to use winbond spi flash (w25q64fv)
but i have a problem with spi as you can see in below image clock stop before receiving data from spi flash, do you have any idea why???
image description
here is what should i see based on datasheet
image description
here is my code for spi_master_init()
static void spi_master_init()
    uint32_t err_code = NRF_SUCCESS;
    // Configure SPI master.
    spi_master_config_t spi_config = SPI_MASTER_INIT_DEFAULT;
	spi_config.SPI_Pin_SCK  	= SPIM0_SCK_PIN;
	spi_config.SPI_Pin_MISO 	= SPIM0_MISO_PIN;
	spi_config.SPI_Pin_MOSI 	= SPIM0_MOSI_PIN;
	spi_config.SPI_Pin_SS   	= SPIM0_SS_PIN;
	spi_config.SPI_CONFIG_CPHA	= SPI_CONFIG_CPHA_Leading;
	spi_config.SPI_CONFIG_CPOL	= SPI_CONFIG_CPOL_ActiveHigh;
	spi_config.SPI_Freq			= SPI_FREQUENCY_FREQUENCY_K500;
    spi_config.SPI_CONFIG_ORDER = SPI_CONFIG_ORDER_MsbFirst;
    err_code = spi_master_open(SPI_MASTER_0, &spi_config);
    // Register event handler for SPI master.
    spi_master_evt_handler_reg(SPI_MASTER_0, spi_master_0_event_handler);
void spi_master_0_event_handler(spi_master_evt_t spi_master_evt)
	// nothing
And here is my code for reading Status Register 1 (w25q64fv)
uint8_t readSR1()
	uint8_t rx_data = 0x00;
	uint8_t tx_data[2] = {0x05, 0xff};
	spi_master_send_recv(SPI_MASTER_0, tx_data, 2, &rx_data, 1);
    return rx_data;
