error repported segger
 Hello, i'm trying to flash a code in my module nrf52805 thx to my Dk nrf52840. i have this error I followed the instructions here: https://devzone.nordicsemi.com/guides/short-range-guides/b/getting-started/posts/developing-for-the-nrf52805-with-nrf5-sdk
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x30000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x6000
FLASH_START=0x15000
FLASH_SIZE=0x15000
RAM_START=0x20000000
RAM_SIZE=0x6000
How can I solve this?
Thank you in advance
    Is your application based on an example, and if so which one? Are you using SoftDevice and/or bootloader in your application?
    The combined MBR and SoftDevice memory requirements of the SoftDevices supported on nRF52805 are as follows:
    SoftDevice s112:
    • Flash: 100.0 kB (0x19000 bytes).
    • RAM: 3.7 kB (0xEB8 bytes). This is the minimum required memory. The actual requirements
      depend on the configuration chosen at sd_ble_enable() time.
    • Call stack: The SoftDevice uses a call stack combined with the application. The worst-case
      stack usage for the SoftDevice is 1.8 kB (0x700 bytes). Application writers should ensure that
      enough stack space is reserved to cover the worst-case SoftDevice call stack usage combined
      with the worst-case application call stack usage
    SoftDevice s113:
    • Flash: 112.0 kB (0x1C000 bytes).
    • RAM: 4.4 kB (0x1198 bytes). This is the minimum required memory. The actual requirements
      with the worst-case application call stack usage.
    If you are using a SoftDevice you must make sure that FLASH_START and RAM_START are not lower than the required flash and RAM for the SoftDevice and MBR. So for s112 you would get:
    • FLASH_START: 0x19000
    • RAM_START: 0x20000EB8
    Marte
  • Hello, i followed the instructions with https://devzone.nordicsemi.com/guides/short-range-guides/b/getting-started/posts/developing-for-the-nrf52805-with-nrf5-sdk
    and i'm trying the example ble-peripheral_uart using segger embedded studio 3125.s113.zip
