NRF_ERROR_NO_MEM in nrf_twi_sensor_write
I'm getting an error NRF_ERROR_NO_MEM when trying to initialize the LPS22HB, and the RTT log shows:
<info> twi_sensor: Write register: 0x0B
<info> twi_sensor: Sensor addr: 0x5C Write length 2
<warning> twi_sensor: Memory not allocated. Sensor addr: 0x5C
<error> app: ERROR 4 [NRF_ERROR_NO_MEM] at :0
PC at: 0x00000000
<error> app: End of error report
The line being triggered is in nrf_twi_sensor.c, line 151, which is nrf_twi_sensor_write().
I've initialized the sensor like this:
NRF_TWI_MNGR_DEF(m_nrf_twi_mngr, MAX_PENDING_TRANSACTIONS, TWI_INSTANCE_ID);
NRF_TWI_SENSOR_DEF(m_twi_sensor, &m_nrf_twi_mngr, 128);
LPS22HB_INSTANCE_DEF(m_lps22b, &m_twi_sensor, TWI_ADDRESS);
    //...other code removed
    lps22hb_init(&m_lps22b);
    lps22hb_data_read(&m_lps22b,&barometer_callback,&baro_data,1);
If I don't handle the error with APP_ERROR_CHECK() the rest of the program runs normally, except for not being able to read anything off the LPS22 sensor. Using nrf SDK version 17.0.2.
  • So as an update, I increased LPS22HB_MIN_QUEUE_SIZE from 4 to 32 in lps22hb.h and the error has changed to 0x09 (NRF_ERROR_INVALID_LENGTH)...
    Did you try to look inside nrf_twi_sensor_write() and debug to figue out why it returns 0x04/0x09?
    When it returned 0x04, was it because nrf_twi_sensor_write_cmd_t * p_cmd was NULL?
    When it returned 0x09, is it because length > NRF_TWI_SENSOR_SEND_BUF_SIZE? What is NRF_TWI_SENSOR_SEND_BUF_SIZE in your case?
    (All of these names are from inside nrf_twi_sensor_write())
    Edvin
  • Hi, apologies for the delay as I only got back to my test setup - p_cmd is indeed returned as NULL when nrf_balloc_alloc() is called.
    If I set LPS22HB_MIN_QUEUE_SIZE to 32 then it hits the if statement in lps22hb_init():
    ret_code_t lps22hb_init(lps22hb_instance_t * p_instance)
        ASSERT(p_instance != NULL);
        p_instance->interrupt_cfg = 0;
        p_instance->ctrl_reg[0]   = 0;
        p_instance->ctrl_reg[1]   = LPS22HB_CTRL_REG2_DEFAULT;
        p_instance->ctrl_reg[2]   = 0;
        p_instance->fifo_ctrl     = 0;
        ret_code_t err_code;
        if (p_instance->p_sensor_data->p_twi_mngr->p_queue->size < LPS22HB_MIN_QUEUE_SIZE)
            return NRF_ERROR_INVALID_LENGTH;
        err_code = lps22hb_cfg_commit(p_instance);
        return err_code;
    p_instance->p_sensor_data->p_twi_mngr->p_queue->size evaluates to 5 which is less than 32.
    So no, it's not because length is more than the buffer size...
  • So where does 5 come from? Is it your MAX_PENDING_TRANSACTIONS, or did you change:
    to
    NRF_TWI_SENSOR_DEF(m_twi_sensor, &m_nrf_twi_mngr, 5);
    I don't have anything that I can compile that uses this library.
    no, it is because your p_queue is less than the minimum queue size.
    Would it be possible to zip and send your project? just a strip down project that replicates the issue.
    Edvin
  • It's our MAX_PENDING_TRANSACTIONS.
    Yes, it's possible to zip and send our project, where should I send it to?
