I'm trying to implement a set up of the ble device name from the NVMC UICR register.
But when I try to take it from the register and to set it has a name, it doesn't work very well. I think this is an issue about the utf-8 encoder of the ble device name.
Here's my code:
1) Write the device name only if it wasn't done before.
static void write_name () { uint32_t* deviceName = (uint32_t*)&NRF_UICR->CUSTOMER[0]; if (*deviceName == 0xFFFFFFFF){ ret_code_t err_code; err_code = nrf_sdh_disable_request(); APP_ERROR_CHECK(err_code); NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Een << NVMC_CONFIG_WEN_Pos; while (NRF_NVMC->READY == NVMC_READY_READY_Busy){} NRF_NVMC->ERASEUICR = NVMC_ERASEUICR_ERASEUICR_Erase; NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos; while (NRF_NVMC->READY == NVMC_READY_READY_Busy){} NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos; while (NRF_NVMC->READY == NVMC_READY_READY_Busy){} uint8_t* name = "WAW-TEST"; NRF_UICR->CUSTOMER[0] = 0xFFFFFFFF & *name; NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos; while (NRF_NVMC->READY == NVMC_READY_READY_Busy){} NVIC_SystemReset(); } }
2) set the ble device name
static void gap_params_init() { ret_code_t err_code; ble_gap_conn_params_t gap_conn_params; ble_gap_conn_sec_mode_t sec_mode; BLE_GAP_CONN_SEC_MODE_SET_OPEN(&sec_mode); uint32_t* deviceName = (uint32_t*)&NRF_UICR->CUSTOMER[0]; uint8_t name = 0xFFFFFF00 | *deviceName; uint8_t* n = &name; NRF_LOG_INFO("%s", (char*)n); if (*deviceName == 0xFFFFFFFF){ err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME)); } else { err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t*)n, strlen(n)); } APP_ERROR_CHECK(err_code); /* YOUR_JOB: Use an appearance value matching the application's use case. err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_); APP_ERROR_CHECK(err_code); */ memset(&gap_conn_params, 0, sizeof(gap_conn_params)); gap_conn_params.min_conn_interval = MIN_CONN_INTERVAL; gap_conn_params.max_conn_interval = MAX_CONN_INTERVAL; gap_conn_params.slave_latency = SLAVE_LATENCY; gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT; err_code = sd_ble_gap_ppcp_set(&gap_conn_params); APP_ERROR_CHECK(err_code); }
Currently, when I search for it, I'm seeing this :
When I should see "WAW-TEST"...
Does someone have a solution to this ?
