MCUBoot + MCUmgr: Image in the secondary slot is not valid!
Hi!
I am working on a custom board and would like to use an external flash for BLE OTA updates. The FW is based on NCS v1.7.1 and MCUBoot as the bootloader. I would like to use the MX25R64 external flash connected via SPI (not QSPI) for the secondary bootloader slot.
I started with the SMP Server sample and got it working on an nRF52840DK using QSPI (see NCS 1.7 ota use external flash). I've followed the discusion ncs-external-flash-ota-change-qspi-to-spi to use SPI instead of QSPI. When using the Android 'Device Manager' App in combination with the provided sample application 1207.hello_world_spi_nor_ext_flash.zip everthing works fine. But the update process fails, if I use the MCUmgr CLI interface for the image upload. In this case I get the error message 'Image in the secondary slot is not valid!'. The MCUmgr CLI runs on a Raspberry PI with an nRF52840 Dongle as BLE HCI Interface.
I also tried tried NCS v1.8.0 and got the same error message.
Debugging MCUBoot with Ozone shows that the image signature/hash is incorrect when using MCUmgr CLI for the image upload. Further investigation of the error shows that the integrity check perforrmed in the bootutil_img_validate function fails. In this case the variable hash is invalid, but the content of the variable buf is correct. When I use the Device Manager App to  upload the image, the signature is valid and the update is successful.
     * Traverse through all of the TLVs, performing any checks we know
     * and are able to do.
    while (true) {
        rc = bootutil_tlv_iter_next(&it, &off, &len, &type);
        if (rc < 0) {
            goto out;
        } else if (rc > 0) {
        if (type == IMAGE_TLV_SHA256) {
             * Verify the SHA256 image hash.  This must always be
             * present.
            if (len != sizeof(hash)) {
                rc = -1;
                goto out;
            rc = LOAD_IMAGE_DATA(hdr, fap, off, buf, sizeof(hash));
            if (rc) {
                goto out;
            FIH_CALL(boot_fih_memequal, fih_rc, hash, buf, sizeof(hash));
            if (fih_not_eq(fih_rc, FIH_SUCCESS)) {
                goto out;
            sha256_valid = 1;
Can you give me any advice to fix the error?
Thomas
    Thank you for providing your test firmware.
    I tried to replicate the issue you are seeing using these commands on the PC side:
    sudo /path/to/mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Nordic_LBS' image upload zephyr/app_update.bin
    Here's the "image list" after successful upload:
    sudo /path/to/mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Nordic_LBS' image list
    Images:
     image=0 slot=0
        version: 0.0.0
        bootable: true
        flags: active confirmed
        hash: 970ee41e6186bebf631aab7aebbc7c7ae0d6b027ac8149f782104c06884673b7
     image=0 slot=1
        version: 0.0.0
        bootable: true
        flags:
        hash: 24bc32212e7cc352aafc82a5143dd3f79bd9819869c548dacaf41d2e2eddfe11
    Split status: N/A (0)
    Now test the second image and see that it is set to "pending" successfully:
    sudo /path/to/mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Nordic_LBS' image test 24bc32212e7cc352aafc82a5143dd3f79bd9819869c548dacaf41d2e2eddfe11
    Images:
     image=0 slot=0
        version: 0.0.0
        bootable: true
     image=0 slot=1
        version: 0.0.0
        bootable: true
        flags: pending
    And here's the output after reset where you can see that the timestamp has changed (image tested OK):
    *** Booting Zephyr OS build v2.6.99-ncs1-1  ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Swap type: none
    I: Bootloader chainload address offset: 0xc000
    Starting Bluetooth Peripheral LBS example
    build time: Jan 19 2022 09:25:17
    I: 2 Sectors of 4096 bytes
    I: alloc wra: 0, fd0
    I: data wra: 0, 1c
    I: SoftDevice Controller build revision:
    I: 3f 47 70 8e 81 95 4e 86 |?Gp...N.
    I: 9d d3 a2 95 88 f6 30 0a |......0.
    I: 7f 53 49 fd             |.SI.
    I: No ID address. App must call settings_load()
    Bluetooth initialized
    Advertising successfully started
    Connected
    I: Swap type: none
    I: Swap type: test
    I: Swap type: test
    Disconnected (reason 19)
    Connected
    I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
    I: Swap type: test
    build time: Jan 19 2022 09:33:22
    I: data wra: 0, 1c
    If the hash is incorrect, then there's a problem with the integrity of the image. Since you are working with a nRF52840-DK, could you try to erase the flash and QSPI flash?
    nrfjprog -e
    nrfjprog --reset
    nrfjprog -qspieraseall
    Then flash your sample.
    Håkon
  • Many thanks for the fast response!
    I followed your steps but still get the same error message.
    As a first step, I erased the flash and QSPI flash
    nrfjprog -e
    nrfjprog --reset
    nrfjprog --qspieraseall
    Than I build and flashed the sample using NCS v1.7.1
    west build -p always -b nrf52840dk_nrf52840
    west flash
    I rebuilt the sample application, copied the update binary to a Raspberry Pi and uploaded the image using MCUmgr
    ubuntu@ubuntu:~$ sudo go/bin/mcumgr -c ble_lbs image upload app_update.bin
     200.50 KiB / 200.50 KiB [======================================================================] 100.00% 9.76 KiB/s 20s
    Done
    List the images
    ubuntu@ubuntu:~$ sudo go/bin/mcumgr -c ble_lbs image list
    Images:
     image=0 slot=0
        version: 0.0.0
        bootable: true
        hash: 30372ead86b3fe06019e4c90d02c2b680bd97195ddc91f20cc5ec68b7516a4a6
     image=0 slot=1
        version: 0.0.0
        bootable: true
        flags:
        hash: 56385894ea602db72850094e158c58afb4925607790ce3d79d64b1024a2a3d3d
    Triggered an image test and reset the device using nrfjprog
    ubuntu@ubuntu:~$ sudo go/bin/mcumgr -c ble_lbs image test 56385894ea602db72850094e158c58afb4925607790ce3d79d64b1024a2a3d
    3d
    Images:
     image=0 slot=0
        version: 0.0.0
        bootable: true
     image=0 slot=1
        version: 0.0.0
        bootable: true
        flags: pending
    However, testing the image fails with the same error message
    I: Swap type: none
    build time: Jan 19 2022 13:30:44
    I: alloc wra: 0, fe8
    I: data wra: 0, 0
    Connected
    I: Swap type: none
    Connected
    I: Swap type: none
    I: Swap type: none
    E: Unable to allocate TX context
    Disconnected (reason 8)
    Connected
    I: Swap type: none
    I: Swap type: none
    Connected
    I: Swap type: none
    I: Swap type: test
    I: Swap type: test
    I: Swap type: test
    E: Image in the secondary slot is not valid!
    I: data wra: 0, 1c
    Did I do something wrong?
    Thomas
    Looks like there's a problem allocating TX packets at your end, this could be due to the bluetooth mtu that your bluetooth host uses. Could you try the following configs
    CONFIG_BT_L2CAP_TX_MTU=252
    CONFIG_BT_BUF_ACL_RX_SIZE=256
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2304
    Håkon
  • Thanks for the info.
    The configuration for the larger MTU size has already been set.
    # Allow for large Bluetooth data packets.
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    Setting the MTU configuration from the throughput example fixes the allocation problem, but the image verification error remains the same
    CONFIG_BT_BUF_ACL_RX_SIZE=251
    CONFIG_BT_BUF_ACL_TX_SIZE=251
    CONFIG_BT_BUF_ACL_TX_COUNT=40
    CONFIG_BT_L2CAP_TX_BUF_COUNT=40
    CONFIG_BT_ATT_PREPARE_COUNT=2
    CONFIG_BT_L2CAP_TX_MTU=247
    CONFIG_BT_CTLR_RX_BUFFERS=2
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    I: Primary image: magic=good, swap_type=0x4, copy_done=0x1, image_ok=0x1
    I: Swap type: none
    build time: Jan 19 2022 15:31:58
    I: data wra: 0, 1c
    Connected
    I: Swap type: none
    Connected
    I: Swap type: none
    I: Swap type: none
    Connected
    I: Swap type: none
    I: Swap type: none
    Connected
    I: Swap type: none
    I: Swap type: test
    I: Swap type: test
    I: Swap type: test
    I: data wra: 0, 1c
    But I think the problem is related to buffer or SPI configuration, cause the image upload throughput is much higher when using MCUmgr and it works in combination with QSPI.
    Thomas
  • I further investigated the error and I think it is somehow related to the image transfer speed. Instead of a Raspberry Pi I used a PC with Ubuntu and did several tests. Before each test I erased the external flash
    The update process works when using the internal HCI device. Upload speed is around 3.0 KiB/s and it took 1m7s.
    When I use the Nordic Dongle with BLE HCI firmware the update process fails. In this case upload speed is about 11,8 KiB/s and takes about 16 seconds.
    Do you have any advice?
