Hi!
I am working on a custom board and would like to use an external flash for BLE OTA updates. The FW is based on NCS v1.7.1 and MCUBoot as the bootloader. I would like to use the MX25R64 external flash connected via SPI (not QSPI) for the secondary bootloader slot.
I started with the SMP Server sample and got it working on an nRF52840DK using QSPI (see NCS 1.7 ota use external flash). I've followed the discusion ncs-external-flash-ota-change-qspi-to-spi to use SPI instead of QSPI. When using the Android 'Device Manager' App in combination with the provided sample application 1207.hello_world_spi_nor_ext_flash.zip everthing works fine. But the update process fails, if I use the MCUmgr CLI interface for the image upload. In this case I get the error message 'Image in the secondary slot is not valid!'. The MCUmgr CLI runs on a Raspberry PI with an nRF52840 Dongle as BLE HCI Interface.
I also tried tried NCS v1.8.0 and got the same error message.
Debugging MCUBoot with Ozone shows that the image signature/hash is incorrect when using MCUmgr CLI for the image upload. Further investigation of the error shows that the integrity check perforrmed in the bootutil_img_validate function fails. In this case the variable hash is invalid, but the content of the variable buf is correct. When I use the Device Manager App to upload the image, the signature is valid and the update is successful.
* Traverse through all of the TLVs, performing any checks we know
* and are able to do.
while (true) {
rc = bootutil_tlv_iter_next(&it, &off, &len, &type);
if (rc < 0) {
goto out;
} else if (rc > 0) {
if (type == IMAGE_TLV_SHA256) {
* Verify the SHA256 image hash. This must always be
* present.
if (len != sizeof(hash)) {
rc = -1;
goto out;
rc = LOAD_IMAGE_DATA(hdr, fap, off, buf, sizeof(hash));
if (rc) {
goto out;
FIH_CALL(boot_fih_memequal, fih_rc, hash, buf, sizeof(hash));
if (fih_not_eq(fih_rc, FIH_SUCCESS)) {
goto out;
sha256_valid = 1;Can you give me any advice to fix the error?
Thomas
