On a custom board, using the NRF52832, we want to know the value of a potentiometer. This value is send via a signal on the AIN5 pin of the NRF52.
So, I tried to set up a code to read the value via the saadc module, but it seems it doesn't work as expected...
Here's my code :
void saadc_callback(nrf_drv_saadc_evt_t const * p_event) { if (p_event->type == NRF_DRV_SAADC_EVT_DONE) { ret_code_t err_code; err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("%d\r\n", p_event->data.done.p_buffer[0]); } } void saadc_init(void) { ret_code_t err_code; nrf_saadc_channel_config_t channel_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5); err_code = nrf_drv_saadc_init(NULL, saadc_callback); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_channel_init(0, &channel_config); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_buffer_convert(m_buffer, SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); } /**@brief Function for application main entry. */ int main(void) { bool erase_bonds; ret_code_t err_code; initLeds(); led_purple(); // Initialize. log_init(); // Initialize the async SVCI interface to bootloader before any interrupts are enabled. //err_code = ble_dfu_buttonless_async_svci_init(); //APP_ERROR_CHECK(err_code); timers_init(); buttons_leds_init(&erase_bonds); power_management_init(); ble_stack_init(); storage_init(); gap_params_init(); //scan_init(); gatt_init(); services_init(); advertising_init(); conn_params_init(); peer_manager_init(); //db_discovery_init(); //lbs_c_init(); // Start execution. NRF_LOG_INFO("Devroye application started."); application_timers_start(); //scan_start(); advertising_start(erase_bonds); saadc_init(); // Enter main loop. for (;;) { nrf_drv_saadc_sample(); idle_state_handle(); } }
My result are the following :
[00:00:02.452,636] <info> app: 90 [00:00:02.527,526] <info> app: 96 [00:00:02.577,453] <info> app: 97 [00:00:04.377,746] <info> app: 102 [00:00:04.452,636] <info> app: 89 [00:00:04.527,526] <info> app: 96 [00:00:04.577,453] <info> app: 98 [00:00:06.377,746] <info> app: 101 [00:00:06.452,636] <info> app: 90 [00:00:06.527,526] <info> app: 96 [00:00:06.577,453] <info> app: 96
And of course, the values are not changing if I changed the value of the potentiometer. I don't understand why is it not working...
Another issue that I had, is that the adc value are showing 3 by 3 with a delay but I've not implemented a delay, so I don't know why...
Thanks for your help !
Chris
