We are using A-GPS in our application to get faster TTFF and will be reading location coordinates after every 5 mins of duration. The application flow looks like:- Connect to LTE network through LwM2M carrier lib ------ Enable PSM mode, Activate GPS, get Long & Lat coordinates, Stop GPS, Disable PSM mode ------ Disconnect LTE modem. (Repeat same steps after 5 mins.).
Randomly, after 1 or 2 hours of long run nRF9160 will stuck at below mentioned logs:
GPS_EVT_AGPS_DATA_NEEDED [03:14:49.960,083] <dbg> nrf9160_gps.gps_priority_set: GPS priority disabled [03:14:49.960,296] <dbg> nrf9160_gps.start: GPS operational [03:14:49.960,388] <dbg> nrf9160_gps.gps_thread: A-GPS data update needed
But this time we could see our test is end up with SUPL error: 3
GPS_EVT_AGPS_DATA_NEEDED [03:14:49.960,083] <dbg> nrf9160_gps.gps_priority_set: GPS priority disabled [03:14:49.960,296] <dbg> nrf9160_gps.start: GPS operational [03:14:49.960,388] <dbg> nrf9160_gps.gps_thread: A-GPS data update needed [03:14:50.222,503] <dbg> agps.open_supl_socket: ip 172.217.215.192 (c0d7d9ac) port 7276 [03:14:50.359,649] <inf> agps: Starting SUPL session [03:14:50.361,694] <dbg> agps.supl_logger: ULP encoding length: 39 [03:14:50.362,243] <dbg> agps.supl_logger: Bytes sent: 39 [03:14:50.534,912] <dbg> agps.supl_logger: Bytes received: 34, total 34 [03:14:50.535,491] <dbg> agps.supl_logger: <log_strdup alloc failed> [03:14:50.535,583] <dbg> agps.supl_logger: <log_strdup alloc failed> [03:14:50.535,644] <dbg> agps.supl_logger: <log_strdup alloc failed> [03:14:50.535,827] <dbg> agps.supl_logger: <log_strdup alloc failed> [03:14:50.536,499] <dbg> agps.supl_logger: <log_strdup alloc failed> [03:14:50.827,117] <dbg> agps.supl_logger: Bytes received: 708, total 708 [03:14:50.827,697] <dbg> agps.supl_logger: ULP ossDecode more input 4 [03:14:51.827,758] <dbg> agps.supl_logger: read again [03:14:52.827,911] <dbg> agps.supl_logger: read again [03:14:53.828,094] <dbg> agps.supl_logger: read again [03:14:54.828,247] <dbg> agps.supl_logger: read again [03:14:55.828,430] <dbg> agps.supl_logger: read again [03:14:56.828,582] <dbg> agps.supl_logger: read again [03:14:57.828,765] <dbg> agps.supl_logger: read again [03:14:58.828,918] <dbg> agps.supl_logger: read again [03:14:59.829,101] <dbg> agps.supl_logger: read again [03:15:00.829,254] <dbg> agps.supl_logger: read again [03:15:01.829,437] <dbg> agps.supl_logger: Timeout expired [03:15:01.829,498] <dbg> agps.supl_logger: SUPL error: 3 [03:15:01.829,650] <dbg> agps.supl_logger: ULP encoding length: 34
GPS Config in application:
static void hubo_gps_start_work_fn(struct k_work *work) {
int err;
/* GPS search configuration. */
struct gps_config gps_cfg = {
.nav_mode = GPS_NAV_MODE_SINGLE_FIX,
.power_mode = GPS_POWER_MODE_DISABLED,
.timeout = GPS_READ_TIMEOUT_MS,
.priority = false,
ARG_UNUSED(work);
/* Start the GPS operation. */
err = gps_start(gps_dev, &gps_cfg);
if (err) {
GPS_DEBUG_PRINTK("Failed to start GPS, error: %d \n", err);
return;
prj.conf file:
CONFIG_FPU=y CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y CONFIG_STDOUT_CONSOLE=y CONFIG_AT_CMD=y # DK CONFIG_DK_LIBRARY=y CONFIG_LWM2M_CARRIER=y CONFIG_NRF_MODEM_LIB_SYS_INIT=n CONFIG_AT_CMD_THREAD_STACK_SIZE=1536 # PDN library CONFIG_PDN=y CONFIG_PDN_CONTEXTS_MAX=3 # Disable NB-IoT fallback CONFIG_LTE_NETWORK_USE_FALLBACK=n # SMS library CONFIG_SMS=y # LwM2M carrier is only compiled for hard-float CONFIG_FPU=y CONFIG_FP_HARDABI=y # Networking CONFIG_NETWORKING=y CONFIG_NET_NATIVE=n CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_POSIX_NAMES=y # LTE link control CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y CONFIG_LTE_AUTO_INIT_AND_CONNECT=n CONFIG_LTE_PSM_REQ_RPTAU="00011111" CONFIG_LTE_PSM_REQ_RAT="00000010" # Modem library CONFIG_NRF_MODEM_LIB=y # FOTA library CONFIG_FOTA_DOWNLOAD=y CONFIG_REBOOT=y # Download client CONFIG_DOWNLOAD_CLIENT=y CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096 # DFU Target CONFIG_DFU_TARGET=y # Application Upgrade support CONFIG_BOOTLOADER_MCUBOOT=y # Image manager CONFIG_IMG_MANAGER=y CONFIG_IMG_ERASE_PROGRESSIVELY=y # Day-Time library CONFIG_DATE_TIME=y CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=3600 # AT Host CONFIG_AT_CMD_PARSER=y CONFIG_AT_HOST_LIBRARY=y # Serial port CONFIG_SERIAL=y CONFIG_UART_NRFX=y CONFIG_UART_INTERRUPT_DRIVEN=y # Have kernel output CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y CONFIG_UART_CONSOLE_ON_DEV_NAME="UART_0" # MQTT CONFIG_MQTT_LIB=y CONFIG_MQTT_LIB_TLS=y CONFIG_MQTT_CLEAN_SESSION=y CONFIG_MODEM_KEY_MGMT=y # Memory CONFIG_MAIN_STACK_SIZE=8192 CONFIG_HEAP_MEM_POOL_SIZE=8192 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 #GPIO required for GPS Amplifier enable/disable CONFIG_GPIO=y #Threads CONFIG_MULTITHREADING=y CONFIG_MAIN_THREAD_PRIORITY=7 #Disable UART CONFIG_BOOT_BANNER=y CONFIG_PRINTK=y CONFIG_LOG=y # Storage CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_NVS=y CONFIG_NVS_LOG_LEVEL_DBG=y CONFIG_REBOOT=y CONFIG_MPU_ALLOW_FLASH_WRITE=y # GPS CONFIG_NRF9160_GPS=y CONFIG_NRF9160_GPS_LOG_LEVEL_DBG=y # AGPS CONFIG_AGPS=y # CONFIG_AGPS_SRC_SUPL=y CONFIG_AGPS_LOG_LEVEL_DBG=y CONFIG_NRF9160_GPS_THREAD_STACK_SIZE=4608 # Compiler CONFIG_NEWLIB_LIBC=y
Can you please support me to solve this issues asap and explain us why and what exactly is happening when we are performing long running test ?
NCS version : 1.6.0
SUPL Lib Version: nrf9160_libsupl-v0.7.1
Modem Firmware version: 1.3.0
Device Revision : NRF9160_xxAA_REV2
Board Version : PCA10090
Thank You !
Chetan
