Softdevice block register access
Hi, I worked with temp sensor example and sofdevice s110 and something stuck on some function. Anyway, I made readout from registers but softdevice blocks register access and code fail. When I delete softdevice I can read temperature easy. Is there any way to prevent softdevice blocking register access?
  • If you read the documentation for the softdevice you'll see the TEMP peripheral is restricted, which means it's blocked from direct access and you can only use it via the softdevice's temperature functions.
    The spec gives the full list of open, blocked and restricted peripherals.
  • Thank you!
