Device crashes when I use a Crystal substitute
When I use the recommended X1 and X2 crystals from Epson (Q22FA12800025 and FC-135 32.768KHZ ±20PPM,9.0PF) the device works properly, crystals from ECS did work too in the past. However due to supply shortage we need to always find replacements for those two crystals. When we use a replacement the device stops working. (The watchdog timer gets triggered everytime after the firmware crashes at ble_stack_init() )
When this happens I try to change the source of LFCLK to internal RC or synthesized but sometimes it works sometimes it does not. I also tried to change CLOCK_LF_ACCURACY to bigger values, it does not work too. I tried with multiple crystal models so far and the only ones working seems to be the (Q22FA12800025 and FC-135 32.768KHZ ±20PPM,9.0PF) and (ECS-320-8-37B-7KM-TR and ECS-.327-9-34B-TR).
I measured the LFCLOCK Xtal frequency and it's 32.68KHz which is within 100ppm accuracy from the 32.768 KHz specified. I could not however measure the 32 MHz crystal (any idea how I can measure this accurately with an oscilloscope ? )
What are your suggestions to solve the issue ? is it indeed a crystal problem or could it be something else ? Have you tried other crystal models ? Have you tried with less known crystal brands (Chinese and Taiwanese brands ) ?
Thanks
