nRF52832 + ESP32 connection
Hi all,
First of all, this is a new field for me, so I'm quite a beginner here. I'm connecting my ESP32 to wifi and I want to send somehow the IP it connects to, to the nRF52832 in my nRF52 Dev Kit.
The Nordic chip doesn't have any library like SoftwareSerial.h. I'm not sure how to use SPI here.
Kind Regards,
Pablo.
  • Hey pablo,
    The first thing you need to do is find out whether the ESP operates as an SPI master or slave.
    The second thing you need to do is study the corresponding nrfx SPI Master Example or SPI Slave Example. In both cases the received data will accessable in the event handler after an SPI transaction has completed.
    Let me know when you get stuck and we'll help you further.
  • The first thing you need to do is find out whether the ESP operates as an SPI master or slave.
    It's just connected to wifi and then I go to http://"WiFi.localIP()", that localIP is the one I want to send to my nordic in any way.
    Let's say I configure it as slave_sender and send successfully the IP.
    If I use nrfx SPI Master Example, how can I test this?
  • looks like the nrfx example does not build for the nRF52832 out of the box, so instead, I want you to use the SPI Master Example.
    For reference here's the main.c file:
     * Copyright (c) 2015 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
    #include "nrf_drv_spi.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "boards.h"
    #include "app_error.h"
    #include <string.h>
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define SPI_INSTANCE  0 /**< SPI instance index. */
    static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
    static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
    #define TEST_STRING "Nordic"
    static uint8_t       m_tx_buf[] = TEST_STRING;           /**< TX buffer. */
    static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];    /**< RX buffer. */
    static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
     * @brief SPI user event handler.
     * @param event
    void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                           void *                    p_context)
        spi_xfer_done = true;
        NRF_LOG_INFO("Transfer completed.");
        if (m_rx_buf[0] != 0)
            NRF_LOG_INFO(" Received:");
            NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
        nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
        spi_config.ss_pin   = SPI_SS_PIN;
        spi_config.miso_pin = SPI_MISO_PIN;
        spi_config.mosi_pin = SPI_MOSI_PIN;
        spi_config.sck_pin  = SPI_SCK_PIN;
        APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
        NRF_LOG_INFO("SPI example started.");
        while (1)
            // Reset rx buffer and transfer done flag
            memset(m_rx_buf, 0, m_length);
            spi_xfer_done = false;
            APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
            while (!spi_xfer_done)
                __WFE();
            NRF_LOG_FLUSH();
            bsp_board_led_invert(BSP_BOARD_LED_0);
            nrf_delay_ms(200);
    I want you to change line 57 from "static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];    /**< RX buffer. */" to:
    "static uint8_t       m_rx_buf["size of the IP address in bytes" + 1];    /**< RX buffer. */"
    And change line 98 from "APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));" to:
    "APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, sizeof(m_rx_buf));
    Then compile, flash, and connect the nRF52DK to a terminal, like putty, etc.
    The example will start an SPI transfer every 200ms, set by nrf_delay_ms() in the main loop.
  • I flashed it and connected it to a terminal. Without connecting the ESP32 I can see "<info> app: Transfer completed." all the time.
    Now, what do I have to do in order to receive data from the ESP32?
  • Connect the proper wires and the SPI event handler will print the content of the RX buffer as long as the first bye is non-zero.
