Is there a way to know the device information that sent the connection request?
Hello.
I used to ask this question to DevZone. However, I made a new question because it is locked and I cannot ask additional questions.
My purpose is to know the bonded device information that sent the connection request. Does this answer mean that you can get information about bonded devices by using a white list?
Or is it possible to know the device information only after connecting?
I really want information such as the MAC address of the other party before connecting.
Please answer.
Best regards.
  • Hello.
    I had a wrong idea because I had only a rough idea of Bluetooth communication. I found that I couldn't get the information. Thank you very much.
    We're discussing some possible ways, but what exactly do we do?
    Best regards.
    Depends on what you want to acheive... ?
  • Hello.
    I found out that I couldn't get the device information in the connection request, so I'm thinking of getting the information in the event "BLE_GAP_EVT_CONNECTED" at the time of connection.
    You said that you can get device information after connecting, but is it correct for connected of p_ble_evt? You can get the device address here, but how do you get the Tx Power and RSSI information?
    Best regards.
  • This is the information you have in the BLE_GAP_EVT_CONNECTED event:
    /**@brief Event structure for @ref BLE_GAP_EVT_CONNECTED. */
    typedef struct
      ble_gap_addr_t        peer_addr;              /**< Bluetooth address of the peer device. If the peer_addr resolved: @ref ble_gap_addr_t::addr_id_peer is set to 1
                                                         and the address is the device's identity address. */
      uint8_t               role;                   /**< BLE role for this connection, see @ref BLE_GAP_ROLES */
      ble_gap_conn_params_t conn_params;            /**< GAP Connection Parameters. */
      uint8_t               adv_handle;             /**< Advertising handle in which advertising has ended.
                                                         This variable is only set if role is set to @ref BLE_GAP_ROLE_PERIPH. */
      ble_gap_adv_data_t    adv_data;               /**< Advertising buffers corresponding to the terminated
                                                         advertising set. The advertising buffers provided in
                                                         @ref sd_ble_gap_adv_set_configure are now released.
    } ble_gap_evt_connected_t;
    (in addition to the conn_handle).
    The event doesn't contain any information on RSSI. To get the RSSI, please see this and similar threads on Devzone.
    The TX power that the central uses isn't available information on the peripheral. If you need that, you need to set this up in a proprietary way. You need to add a service that the central can write it's TX power into. The central doesn't broadcast this in any way.
    Edvin
  • Hello.
    Thank you for the information.
    I am going to use it as an example.
    Best regards.
