802.15.4 callback Issues
We are developing a wireless protocol based upon 802.15.4 for nRF52840 and have some trouble with the MAC layer. To begin with, a mlme reset is requested and then an active scan.
The first issue is memory allocation, using sys_mm_alloc() to allocate memory (it is initialized beforehand) results in no callbacks after requests for either reset or scan. If swapped out for malloc instead the callbacks occur.
The reset callback seems to be fine but the scan confimation data is weird. For each channel scanned a PAN is found with id 0, the only PAN that should be found is a zigbee coordinator with an ID that is not 0 on channel 11. It also seems sys_task_run must be run for the callbacks to happen, but it is not clear whether it is required to use the system scheduler or not for 802.15.4
Questions:
1. Is the system scheduler required for using the 802.15.4 primitives?
2. Is the system memory allocater required or is using malloc fine?
3. Is there any SDK_CONFIG parameters that need to be set?
4. Is the source code available somewhere?
The sdk used is nRF5 SDK
Thanks in advance
  • Hi Marte,
    Just got hands on a second nrf52840 to use as sniffer. Will come back with logs later today or possibly tomorrow.
    Thanks for the checkup.
    Best Regards,
    Andreas
  • Due to some OS issues noticed when installing wireshark I ended up reinstalling Ubuntu from scratch and the development environment as well of course. For some reason everything started working fine after this without any changes in the code.
    If I had to guess the reason for the issue it could have been the wrong compiler version or that the 802.15.4 binary was corrupt. If anyone else have similar issues I will leave the correct code for making an active scan below.
    Note that scan type and scan duration is hardcoded in the example.
    Thanks Marte for the help.
    #define CONFIRM_SCAN_SIZE 7
    void mlme_scan_conf_cb(mlme_scan_conf_t * scan_report)
       NRF_LOG_INFO("Status: %X", scan_report->status);
       if(scan_report->status == MAC_SUCCESS)
          if(scan_report->result_list_size > CONFIRM_SCAN_SIZE )
             NRF_LOG_INFO("Number of results surpassed memory allocated in scan");
          NRF_LOG_INFO("Received 802.15.4 scan report");
          NRF_LOG_INFO("Found %d PANs", scan_report->result_list_size);
          NRF_LOG_INFO("unscanned channels: %X", scan_report->unscanned_channels);
          for(int i = 0; i < scan_report->result_list_size; i++ )
             NRF_LOG_INFO("Found PAN with ID: %X", scan_report->pan_descriptor_list[i].coord_pan_id);
    static mlme_scan_req_t *scan_request;
    void scan()
       scan_request = (mlme_scan_req_t *)malloc(sizeof(mlme_scan_req_t));
       ASSERT(scan_request != NULL);
       scan_request->pan_descriptors_buf = (mac_pan_descriptor_t *) malloc(sizeof(mac_pan_descriptor_t) *  CONFIRM_SCAN_SIZE);
       scan_request->pan_descriptors_buf_size =  CONFIRM_SCAN_SIZE;
       scan_request->energy_detect_buf = malloc(sizeof(uint8_t) *  CONFIRM_SCAN_SIZE);
       scan_request->energy_detect_buf_size =  CONFIRM_SCAN_SIZE;
       ASSERT(scan_request->energy_detect_buf != NULL);
       ASSERT(scan_request->pan_descriptors_buf != NULL);
       uint32_t channelMask;
       channelMask = 0b00000111111111111111100000000000;
       scan_request->scan_type = 1;
       scan_request->scan_channels = channelMask;
       scan_request->scan_duration = 4;
       mlme_scan_req(scan_request, mlme_scan_conf_cb);
       NRF_LOG_INFO("Scanning");
    Best Regards,
    Andreas
  • Hi Andreas,
    Good to hear that the issue solved itself, even if you had to reinstall everything Slight smile
    Thank you for sharing your code here for others to find, it is greatly appreciated!
    Marte
  • I found the actual issue or at least what made active scan work.
    Calling
    ral_irq_handlers_import()
    was required for active scan to properly work. I have no way of telling why, I'm not using the RAL module at all and it isn't mentioned in the documentation as an requirement.
    I have been trying to look internally, but I cannot find anywhere stating why this function is needed. However, I see that it is called at the beginning of main() in the 802.15.4 Wireless UART example as well. I suspect that it is necessary for RADIO IRQ to work and be handled correctly.
    Marte
