802.15.4 callback Issues
We are developing a wireless protocol based upon 802.15.4 for nRF52840 and have some trouble with the MAC layer. To begin with, a mlme reset is requested and then an active scan.
The first issue is memory allocation, using sys_mm_alloc() to allocate memory (it is initialized beforehand) results in no callbacks after requests for either reset or scan. If swapped out for malloc instead the callbacks occur.
The reset callback seems to be fine but the scan confimation data is weird. For each channel scanned a PAN is found with id 0, the only PAN that should be found is a zigbee coordinator with an ID that is not 0 on channel 11. It also seems sys_task_run must be run for the callbacks to happen, but it is not clear whether it is required to use the system scheduler or not for 802.15.4
Questions:
1. Is the system scheduler required for using the 802.15.4 primitives?
2. Is the system memory allocater required or is using malloc fine?
3. Is there any SDK_CONFIG parameters that need to be set?
4. Is the source code available somewhere?
The sdk used is nRF5 SDK
Thanks in advance
    Q1
    From what I can find it seems like calling sys_task_run() is required, but I will check with the developers to make sure.
    Q2
    It is not required to use sys_mm_alloc(). There are some other cases where using this to allocate memory leads to the scan request callback not being called: https://devzone.nordicsemi.com/f/nordic-q-a/56163/nrf-802-15-4-stack-api-mlme_scan_req-does-not-call-the-callback-function and https://devzone.nordicsemi.com/f/nordic-q-a/59282/802-15-4-mlme_scan_req-never-calls-it-s-callback-function-802-15-4-library-mlme_scan_request_primitive-is-not-according-to-802-15-4_2006-spezification.
    I checked internally, and I cannot find cases of sys_mm_alloc being used for the MLME-SCAN-request or MLME-RESET.request. It is used to allocate memory for packets, for example:
    test_packet_t * packet_to_send = (test_packet_t *)sys_mm_alloc(sizeof(test_packet_t));
    But scan and reset request are mostly done in the same way as in the comment of the first case I link to above:
    static mlme_reset_req_t mlme_reset_req_container =
        .set_default_pib = true
      mlme_reset_req(&mlme_reset_req_container, SetupSeqResetMlmeCb);
    Q3
    Not that I am aware of, but I will check this out.
    Q4
    No, the source code for the library is unfortunately not publicly available.
    I will talk with the developers and see if they might have any ideas as to why the scan confirmation data is as it is.
    Marte
  • Thanks for the quick reply.
    I see then most of my issues seems to be resolved.
    After trying each type of scan except orphan scan, ED scan seems to work as intended, passive scan returns MAC_NO_BEACON which might be correct, a Zigbee Coordinator is setup close to the device as a test but I'm not sure if a Zigbee coordinator requires some additional settings to periodically send a beacon signal.
    However the Active scan never returns no matter what, according to the standard it should return after the scan duration with a confirm. Does active scan have additoinal requirements than passive and ED scans?
    Best Regards, Andreas
  • Hi Andreas,
    I am happy to hear that!
    This sounds like the correct behavior. With passive scan the device can locate a coordinator transmitting beacon frames within its personal operating space (POS). The device does not, however, transmit a beacon requests during a passive scan.
    To periodically send beacon frames the network must be a beacon-enabled PAN. In such a network you will have at least one device transmitting beacon frames at a regular interval. When this is not the case, the coordinator will only send beacons as a response to a beacon request.
    The scans differ in how they work at least. With ED (energy detection) scan the device performs an energy detection measurement on the different channels, while during active scan the device transmits a beacon request and waits to receive a beacon. The Zigbee coordinator should have responded to the beacon request with a beacon frame.
    Do you know wheter macAutoRequest is set to true or false? For active and passive scans, the MLME-SCAN.confirm primitive will only include a set of PAN descriptor values of the scan is successful and macAutoRequest is set to TRUE. If not, it will contain a null set of PAN descriptor values.
    Do you have an additional nRF52840 Dongle or DK? If so, you can use it as a sniffer to capture packets using our nRF Sniffer for 802.15.4. This might help in finding out where the issue is, as you will be able to see if the device sends a beacon request during the active scan or not, and whether the Zigbee coordinator responds to the beacon. If you upload the sniffer log as a pcap file I can look at it to see if I find any issues with the network traffic.
    Marte
  • I have confirmed that macAutoRequest is set to true. What I find odd is that the confirm primitive is never called when an Active scan is requested regardless if there is a coordinator in the vicinity or not.
    Will come back with results from nRF sniffer, thanks.
  • Hi Andreas,
    Have you managed to get a sniffer log of the active scan?
    Marte
