I have modified flash_placement.xml to define a 64 byte RAM region to be used to preserve data across soft resets. It compiles and links but the memory seems to be set to zeros on reset initialization.
This is part of flash_placement.xml. (I have tried load="No" as well)
<ProgramSection alignment="4" load="No" name=".tbss" />
<ProgramSection alignment="4" load="No" name=".non_init" />
<ProgramSection alignment="8" keep="Yes" size="$(EWAVE_DATA_SIZE)" load="Yes" name=".ewave"/>
<ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
<ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack" address_symbol="__StackLimit" end_symbol="__StackTop"/>
<ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
This is the map file output:
0x0000000020007128 __ewave_load_start__ = ALIGN (__non_init_end__, 0x8)
.ewave 0x0000000020007128 0x40
0x0000000020007128 __ewave_start__ = .
*(.ewave .ewave.*)
0x0000000020007168 . = ALIGN (MAX ((__ewave_start__ + 0x40), .), 0x8)
*fill* 0x0000000020007128 0x40
0x0000000020007168 __ewave_end__ = (__ewave_start__ + SIZEOF (.ewave))
0x0000000000000040 __ewave_size__ = SIZEOF (.ewave)
0x0000000020007168 __ewave_load_end__ = __ewave_end__
0x0000000000000001 . = ASSERT (((__ewave_start__ == __ewave_end__) || ((__ewave_end__ - __RAM1_segment_start__) <= __RAM1_segment_size__)), error: .ewave is too large to fit
It appears it is defined to be *filled* and I don't know how to disable that.
TIA
