Soft device enable and disable - [DFU] disconnected by the remote device
Hello all
I am facing a very strange issue, already searched the forum but didnt find anything like it.
Okay so I can get DFU to work. For our custom application we have to disable the soft device for some time for sensor acquisitions and re enable it at a later time for OTA upgrades.
I simply use nrf_sdh_disable_request() to de initialize the soft device successfully, which it does.
I later re - enable soft device using the standard ble calls in example code:
ble_stack_init();
    peer_manager_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init_2();
    conn_params_init();
    //Start execution.
    application_timers_start();
    advertising_start(erase_bonds);
BLE gets initialized successfully, device is advertised and connects to as well. The problem is in DFU. When I attempt DFU, it keeps getting stuck into trying to switch to bootloader, repeatedly giving
"[DFU] disconnected by the remote device"
The logs then try to open the firmware file again, re initiating the process but nothing happen. I have spend quite some time on this and hit a blocker. Any help is appreciated. There must be a step I am missing during re-enabling the soft device
  • Hi. Thanks for the response
    The device is reset when you enter DFU mode, so the central has to re-connect, and then encrypt the link again with the LTK
    No. The current session will be terminated when you enter dfu mode.
    Okay regarding this, I have removed the disconnect functionality from BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE event and the DFU still works. The connection seems to be maintained, so is the link encrypted in DFU mode or not? If the answer is yes here then I will be very relieved. I don't see a disconnection or an NRF log event fire up saying disconnection
    Note that you don't need bond forwarding to support bonding in the main app.
    Okay so I can just set SEC_PARAM_BOND to 1 and not set DFU bond forwarding flags in sdk_config.h? Can I do that?
    My impression is that very few use pairing, so that may explain why it has not been addressed, assuming it is indeed a bug.
    Okay so I dont mind using bonding, but I am having problems for link encryption.
    When you speak of:
    The crypto libraries are only needed for the DH key exchange that takes place during the bonding procedure. Link encryption is done with the built-in AES HW block after the app has provided the softdevice with the LTK, and has no additional SW dependencies.
    Do you mean that even if I dont include crypto libraries, and especially if I don't see BLE_GAP_EVT_LESC_DHKEY_REQUEST exchange, the link layer is encrypted? i.e, By just enabling bond forwarding conventional example. the layer is encrypted? I dont think so, what do you think?
    Dont I need to enable LESC associated flags in SDK and peer manager?
    If the answer is yes, when I do that (enable LESC, add crypto AND enable bonding and bond forwarding), the solution doesn't work 100%. There are a few bonding problems here and there. I will post them next
    The transition from app to bootloader is transparent seen from the user. You have to view the debug logs in nRF connect to see that the connection gets terminated after ble_dfu_buttonless_bootloader_start_finalize() call in your main app, and re-established once the bootloader starts advertising again on the following boot.
    ble_dfu_buttonless_bootloader_start_finalize() will perform a system reset and cause the device to boot into the bootloader, which will then enter DFU mode and start connectable advertising.
    Yes you can. Users still have to be bonded to initiate buttonless DFU as long as you have increased the sec. level of the buttonless characteristic.
    No, what I meant to say is that these crypto libraries are only used for the bonding procedure where the encryption key is exchanged. So you do need these libraries to support LESC bonding in the app. But the pairing method does not affect the security of the bootloader (not directly at least), it simply uses the app provided encryption key to secure the link.
    Yes, if you want LESC bonding, and not legacy bonding.
  • Hmm
    So bottomline is that the session is not encrypted when I go into DFU Mode if I just pair from base firmware? RIght?
    Having said that, I managed to implement Bonding + LESC but its quite buggy I have to say, Sometimes there is GATT Error and what not, I'll update this post soon
    Also, with this implementation DFU only works in the second, third or even fourth try sometimes. It does upload, but after 50,60,70 % it just resets the device being unable to DFU. What could be the issue?
    Btw
    This doesnt work, it was giving me error on ble_dfu_buttonless_async_svci_init(). I did secure the characteristic. Now I was assuming this occurred as the Bootloader supported bonds, but the application did not. Hence, I didnt move forward with it. What could be the issue?
    I just want my DFU to be encrypted btw, thats the ultimate goal.
  • ble_dfu_buttonless_bootloader_start_finalize() will perform a system reset and cause the device to boot into the bootloader, which will then enter DFU mode and start connectable advertising.
    Yes I know. I dont know much about connectable advertising though so please fill me in? The device auto connects and starts DFU instantly, but the key is lost in pairing mode then? The temporary key generated when the main app was running, it's gone then? That's why I need to bond and use the LTK?
  • This doesnt work, it was giving me error on ble_dfu_buttonless_async_svci_init(). I did secure the characteristic. Now I was assuming this occurred as the Bootloader supported bonds, but the application did not. Hence, I didnt move forward with it. What could be the issue?
    This indicates that the NRF_DFU_BLE_REQUIRES_BONDS setting in your bootloader does not match the one used in your app. They have to be set to the same. Otherwise, the SVC interface between the bootloader and app will not be compatible (Supervisor call interface).
    Steps to test DFU with bond farwing using the original SDK examples:
    1. Build the bootloader and and buttonless template app with NRF_DFU_BLE_REQUIRES_BONDS == 1
    2. Program bootloader, softdevice, app, and bootloader settings page to the target device
    3. Connect and bond with the target device using nRF connect app
    4. Upload a signed DFU package.
    Yes this is why you need to bond. The short term key exchanged during pairing is only valid for the given connection, while a LTK will remain valid across connections.
