Soft device enable and disable - [DFU] disconnected by the remote device
Hello all
I am facing a very strange issue, already searched the forum but didnt find anything like it.
Okay so I can get DFU to work. For our custom application we have to disable the soft device for some time for sensor acquisitions and re enable it at a later time for OTA upgrades.
I simply use nrf_sdh_disable_request() to de initialize the soft device successfully, which it does.
I later re - enable soft device using the standard ble calls in example code:
ble_stack_init();
    peer_manager_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init_2();
    conn_params_init();
    //Start execution.
    application_timers_start();
    advertising_start(erase_bonds);
BLE gets initialized successfully, device is advertised and connects to as well. The problem is in DFU. When I attempt DFU, it keeps getting stuck into trying to switch to bootloader, repeatedly giving
"[DFU] disconnected by the remote device"
The logs then try to open the firmware file again, re initiating the process but nothing happen. I have spend quite some time on this and hit a blocker. Any help is appreciated. There must be a step I am missing during re-enabling the soft device
  • They have to be set to the same.
    Didnt you say that I can just configure bonding and not set any DFU bonding flags in SDK? (See below my statement from the previous answer)
    Okay so I can just set SEC_PARAM_BOND to 1 and not set DFU bond forwarding flags in sdk_config.h? Can I do that?
    By the SDK bonding flags I meant this actually NRF_DFU_BLE_REQUIRES_BONDS.. Kindly verify. Sorry man I am a bit confused about this. It caught my eye when you said I can just set SEC_PARAM_BOND on the main app so that I can bond without setting anything DFU_ BOND related in BL or APP.
    I think it cant work without it, as the peer manager saves the session data while shifting from APP to DFU Mode BL
    Yes this is why you need to bond. The short term key exchanged during pairing is only valid for the given connection, while a LTK will remain valid across connections.
    Okay this is great, thanks I got it. Just wanna know out of curiosity the question at the start of the post.
    Regarding the problems I am facing when I configure NRF_DFU_BLE_REQUIRES_BONDS in both APP + BL + LESC
    Problems such as DFU retries and GATT errors, any ideas right off the bat? I will be sharing exact error logs here today itself though
  • Didnt you say that I can just configure bonding and not set any DFU bonding flags in SDK? (See below my statement from the previous answer)
    Yes. This is also the default configuration used in the buttonless template example. That is, bonding enabled but no bond forwarding to the bootloader. So this configuration allows you to secure connections during normal use while the main app is running, but not when you are in DFU mode.
    The point is that NRF_DFU_BLE_REQUIRES_BONDS settings must match. You can't disable NRF_DFU_BLE_REQUIRES_BONDS in the app if it is enabled in the bootloader, and vice versa.
    For Buttonless Secure DFU with bonds and encrypted connections during DFU, you must enable both SEC_PARAM_BOND and NRF_DFU_BLE_REQUIRES_BONDS
    I need more to go on I'm afraid. This can be a lot of things. Can you try repeat the test with our pre-compiled app and bootloader to see if you experience the same issues?
    Testing Buttonless Secure DFU with bonds
  • For Buttonless Secure DFU with bonds and encrypted connections during DFU, you must enable both SEC_PARAM_BOND and NRF_DFU_BLE_REQUIRES_BONDS
    I got that now, Thanks.
    Yes I repeated it. The same issue persists in Buttonless DFU example with bonds but it's a bit lesser than my custom Secure bonds + LESC
    Buttonless example with Bonds
    1) GATT Write not Permit
    Happens mostly just once
    2) GATT Conn Timeout
    Happens mostly just once (Second try though). Sometimes both error occur together (1) and (2)
    3) DFU Retry
    Okay so after the above two errors which usually occur once (either ones). There is a guaranteed DFU retry, the peer gets disconnected.. idk why But it always happens and on the second retry its successful, but I have also noticed that the disconnection happens and the DFU restarts again on its own from 0%.
    2) Custom APP - Bonding + LESC
    Okay so the errors are same but the GATT errors sometimes occurs 3-4 times, and retry is also 2-3 times. It's mostly automatic, as in the DFU stops somewhere in between around 60% and retires again automatically. I also found it happening with just one retry too sometimes (like the example)
    Point is the issue is with example project as well. Btw we are making our own app so perhaps we can negate it, the DFU is always successful though, just retires and stuff.
    Note: In case of GATT error DFU has to be attempted again manually by user, in case of retries mostly it's automatic, in between of DFU it will start to re-attempt. Also regarding retry, the DFU always starts successfully at least.
    Its the final nail in the coffin Vidar... You have been of tremendous help
    This is good progress. Though I don't think I have seen this instability problem before. Are you using the same phone for all your tests? My guess is that it might be a timing related issue. In that case, it's probably something you can work around in your app
    As a test, maybe you could try entering DFU mode manually through nrfconnect by following the message sequence chart here: Message sequence charts
  • Yes I am using the same phone, does that matter? I have an old Nokia 6.1 Plus though. It's not a very recent phone
    Okay I will try using nRF Connect and let you know, I'll use the dongle.
    Also, what kind of timing issue it might be?
