Warning/error: "No SOURCES given to Zephyr library:"
I am building my Project in an out-of-tree form and up to this point I solely used Segger Embedded Studio to compile our project. I am using a custom board with an nrf9160.
Since I now want to use a building pipe line I used the command line "west build" command and found some concerning warnings. Unfortunately I found very little information when searching for these warnings.
C:\Custom_TEST_Application_V1>west build -b TEST_module_ns -p
Including boilerplate (Zephyr base (cached)): C:/ncs/v1.7.1/zephyr/cmake/app/boilerplate.cmake
CMake Deprecation Warning at C:/ncs/v1.7.1/zephyr/cmake/app/boilerplate.cmake:37 (cmake_policy):
  The OLD behavior for policy CMP0079 will be removed from a future version
  of CMake.
  The cmake-policies(7) manual explains that the OLD behaviors of all
  policies are deprecated and that a policy should be set to OLD only under
  specific short-term circumstances.  Projects should be ported to the NEW
  behavior and not rely on setting a policy to OLD.
  C:/ncs/v1.7.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
  C:/ncs/v1.7.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
  CMakeLists.txt:12 (find_package)
-- Application: C:/Custom_TEST_Application_V1
-- Using NCS Toolchain 1.7.1 for building. (C:/ncs/v1.7.1/toolchain/cmake)
-- Zephyr version: 2.6.99 (C:/ncs/v1.7.1/zephyr), build: v2.6.99-ncs1-1
-- Found Python3: C:/ncs/v1.7.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.11.1", minimum required is "0.7.1")
-- Board: TEST_module_ns
-- Cache files will be written to: C:/ncs/v1.7.1/zephyr/.cache
-- Found dtc: C:/ncs/v1.7.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/ncs/v1.7.1/toolchain/opt)
-- Found BOARD.dts: C:/Custom_TEST_Application_V1/boards/arm/TEST_module/TEST_module_ns.dts
-- Generated zephyr.dts: C:/Custom_TEST_Application_V1/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Custom_TEST_Application_V1/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Custom_TEST_Application_V1/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Custom_TEST_Application_V1/build/zephyr/dts.cmake
Parsing C:/Custom_TEST_Application_V1/Kconfig
Loaded configuration 'C:/Custom_TEST_Application_V1/boards/arm/TEST_module/TEST_module_ns_defconfig'
Merged configuration 'C:/Custom_TEST_Application_V1/prj.conf'
Configuration saved to 'C:/Custom_TEST_Application_V1/build/zephyr/.config'
Kconfig header saved to 'C:/Custom_TEST_Application_V1/build/zephyr/include/generated/autoconf.h'
warning: I2C_1 (defined at drivers/i2c/Kconfig.esp32:18) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: I2C_ESP32 (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_I2C_1.html and/or look up I2C_1 in the
menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/ncs/v1.7.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
Changed board to secure TEST_module (NOT NS)
=== child image spm -  begin ===
Including boilerplate (Zephyr base): C:/ncs/v1.7.1/zephyr/cmake/app/boilerplate.cmake
  of CMake.
  C:/ncs/v1.7.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
  CMakeLists.txt:8 (find_package)
-- Application: C:/ncs/v1.7.1/nrf/samples/spm
-- Found BOARD.dts: C:/Custom_TEST_Application_V1/boards/arm/TEST_module/TEST_module.dts
-- Generated zephyr.dts: C:/Custom_TEST_Application_V1/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Custom_TEST_Application_V1/build/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Custom_TEST_Application_V1/build/spm/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Custom_TEST_Application_V1/build/spm/zephyr/dts.cmake
Parsing C:/ncs/v1.7.1/zephyr/Kconfig
Loaded configuration 'C:/Custom_TEST_Application_V1/boards/arm/TEST_module/TEST_module_defconfig'
Merged configuration 'C:/ncs/v1.7.1/nrf/samples/spm/prj.conf'
Merged configuration 'C:/ncs/v1.7.1/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/Custom_TEST_Application_V1/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Custom_TEST_Application_V1/build/spm/zephyr/.config'
Kconfig header saved to 'C:/Custom_TEST_Application_V1/build/spm/zephyr/include/generated/autoconf.h'
CMake Warning (dev) at C:/ncs/v1.7.1/nrfxlib/nrf_security/cmake/extensions.cmake:652:
  Syntax Warning in cmake code at column 32
  Argument not separated from preceding token by whitespace.
  C:/ncs/v1.7.1/nrfxlib/nrf_security/CMakeLists.txt:185 (include)
This warning is for project developers.  Use -Wno-dev to suppress it.
CMake Warning at C:/ncs/v1.7.1/zephyr/CMakeLists.txt:718 (message):
  ..__..__..__Custom_TEST_Application_V1__boards__arm__TEST_module
  Excluding target from build.
CMake Warning at C:/ncs/v1.7.1/zephyr/CMakeLists.txt:1612 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Custom_TEST_Application_V1/build/spm
=== child image spm -  end ===
=== child image mcuboot -  begin ===
  of CMake.
-- Application: C:/ncs/v1.7.1/bootloader/mcuboot/boot/zephyr
  CMakeLists.txt:44 (find_package)
-- Found devicetree overlay: C:/ncs/v1.7.1/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: C:/Custom_TEST_Application_V1/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Custom_TEST_Application_V1/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Custom_TEST_Application_V1/build/mcuboot/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Custom_TEST_Application_V1/build/mcuboot/zephyr/dts.cmake
warning: CONSOLE_HANDLER (defined at drivers/console/Kconfig:39) was assigned the value 'y' but got
the value 'n'. Check these unsatisfied dependencies: UART_CONSOLE (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_CONSOLE_HANDLER.html and/or look up
CONSOLE_HANDLER in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
Parsing C:/ncs/v1.7.1/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration 'C:/ncs/v1.7.1/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/Custom_TEST_Application_V1/mcuboot.conf'
Configuration saved to 'C:/Custom_TEST_Application_V1/build/mcuboot/zephyr/.config'
Kconfig header saved to 'C:/Custom_TEST_Application_V1/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: C:/Custom-TEST-module/src/Custom_TEST_Application_V1/KeyFiles/TEST_private_key.pem
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Custom_TEST_Application_V1/build/mcuboot
=== child image mcuboot -  end ===
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
-- Configuring done
-- Generating done
The concerning building warnings are:
It seams that some of the supplied files are not recognized and the tool chain just ignores them.
To test if these warnings are the result of an out-of-tree build the hello_world sample was also build in an out-of-tree fashion with the nrf9160dk board files and the warnings did not appear.
I hope that someone can help me to solve these warnings or had similar problems.
Please let me know if additional files are needed for the problem analysis and I will try to provide them.
Andreas
