I'm trying to use a nrf delay to make a delay for a motor. The idea is to make the motor oscillated by putting it forward and then reverse via a delay. (you can find this logic at the line 124, the function "oscillate").
But when I want to run the code, I got an issue, the delay is running before the motor is going forward (line 128 with the 1st pwm active). I don't understand why...
The delay is defined via math's formula at the line 77. I tried to put it as a constant and here's the troubleshoot :
- With the delay as 3000 ms, we clearly see the delay before the motor starts spinning forward.
- With the delay as 100ms, we don't see it, but it's probably there but the human eye can not see it
So what I want to resolve in my code is that this angluation_delay is running before my motor starts spinning when I want first the motor to spin forward, and then the delay to active.
#define SAMPLES_IN_BUFFER 1 //Number of SAADC samples in RAM before returning a SAADC event. For low power SAADC set this constant to 1. Otherwise the EasyDMA will be enabled for an extended time which consumes high current.
#define MOTOR_FORWARD 34
#define MOTOR_REVERSE 35
#define MOTOR_MAX_RPM 50000
static nrf_saadc_value_t m_buffer[SAMPLES_IN_BUFFER];
bool test;
uint16_t motor_angluar_max_speed = MOTOR_MAX_RPM*2*M_PI/60;
uint8_t pourcent_speed;
static nrf_drv_pwm_t m_pwm0 = NRF_DRV_PWM_INSTANCE(0);
int gLEDG = MOTOR_FORWARD;
static uint16_t const m_top = 255;
static nrf_pwm_values_individual_t seq_values;
static nrf_pwm_sequence_t const seq =
.values.p_individual = &seq_values,
.length = NRF_PWM_VALUES_LENGTH(seq_values),
.repeats = 0,
.end_delay = 0
uint16_t speed;
uint8_t angulation = 90;
uint32_t angulation_delay;
void update_pwm(uint16_t duty_forward, uint16_t duty_reverse)
seq_values.channel_0 = m_top-duty_forward;
seq_values.channel_1 = m_top-duty_reverse;
nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1, NRF_DRV_PWM_FLAG_LOOP);
nrf_pwr_mgmt_run();
uint32_t get_rtc_counter(void)
return NRF_RTC2->COUNTER;
static void log_init(void)
ret_code_t err_code = NRF_LOG_INIT(get_rtc_counter);
ret_code_t err_code;
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
if (p_event->data.done.p_buffer[0] <= 0){
speed = 0;
} else{
speed = p_event->data.done.p_buffer[0];
//NRF_LOG_INFO("SPEED %d\r\n", speed);
pourcent_speed = floor(speed*100/255);
//NRF_LOG_INFO("POURCENT %d", pourcent_speed);
float angulation_rad = angulation * (M_PI / 180.0);
float number = (angulation_rad/(motor_angluar_max_speed*pourcent_speed/100))*100000;
angulation_delay = (uint32_t) floor(number);
//NRF_LOG_INFO("DELAY %d\r\n", angulation_delay);
void saadc_init(void)
nrf_saadc_channel_config_t channel_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
////Configure SAADC
nrf_drv_saadc_config_t saadc_config;
saadc_config.resolution = NRF_SAADC_RESOLUTION_8BIT;
err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
err_code = nrf_drv_saadc_channel_init(0, &channel_config);
err_code = nrf_drv_saadc_buffer_convert(m_buffer, SAMPLES_IN_BUFFER);
static void pwm_init(void)
uint32_t err_code;
nrf_drv_pwm_config_t const config0 =
.output_pins =
MOTOR_FORWARD, // channel 0
MOTOR_REVERSE, // channel 1
NRF_DRV_PWM_PIN_NOT_USED, // channel 2
NRF_DRV_PWM_PIN_NOT_USED // channel 3
.irq_priority = APP_IRQ_PRIORITY_LOWEST,
.base_clock = NRF_PWM_CLK_16MHz,
.count_mode = NRF_PWM_MODE_UP,
.top_value = m_top,
.load_mode = NRF_PWM_LOAD_INDIVIDUAL,
.step_mode = NRF_PWM_STEP_AUTO
err_code = nrf_drv_pwm_init(&m_pwm0, &config0, NULL);
static void oscillate(void)
if (pourcent_speed > 5)
update_pwm(speed, 0);
nrf_delay_ms(angulation_delay);
update_pwm(0, speed);
} else
update_pwm(0, 0);
/**@brief Function for application main entry.
bool erase_bonds;
// Initialize.
log_init();
saadc_init();
pwm_init();
NRF_LOG_INFO("START");
for (;;)
nrf_drv_saadc_sample();
oscillate();
idle_state_handle();
Thanks for your answers,
Chris
