Hi
As title. Thanks.
Jeffery
Hi
As title. Thanks.
Jeffery
If I tried NRF52840, it's ok to get/set TX power.
The nRF5340 supports up to 0 dBm output power in the register
In order to boost the output power, you should request a higher voltage in the VREGRADIO.VREQH
Priyanka
Hi Priyanka
My question was not only for how to set TX power, but also for how to get TX power.
I found it can not get TX power if selected NRF5340 DK at hci_pwr_ctrl example.
Please try to verify it. Thanks.
Jeffery
You could try referring to this ticket. Are you able to run the sample? It should work on nRF5340. Are you using a PDK or a DK? What is the version of your SDK?
Priyanka
Hi Priyanka
After referring to the ticket as you mentioned, it still cannot get tx power at advertising or connecting stage.
I programmed hcirpmsg sample at network core.
DK board is PCA10095 v1.0.0. And, SDK Connect v1.8.0.
Maybe, you can come out a application core hex file to me for verifying at my side.
Thanks.
Jeffery
