I am trying to erase and flash a nRF52840 chip on a custom board. I use a J-Link EDUwith the Cortex M adapter to plug onto the board. I checked the hardware conf several times, it looks fine to me.
I am running Linux Mint 20.3 on Windows VirtualBox.
Running nrfjprog -v delivers the following:
nrfjprog version: 10.15.2 external
JLinkARM.dll version: 7.60e
I attached the corresponding log.log file. Do you have an idea where the problem might be ?
Thanks in advance for your help.
Nicolas G.
[2022-Jan-26 11:20:07] [ info] --------------------------------------------------------------------------------
[2022-Jan-26 11:20:07] [ info] nrfjprog --eraseall -f nrf52 --log /home/nicolas/Documents/motion_s_fw/logs
[2022-Jan-26 11:20:07] [ info] nrfjprog version 10.15.2 external
[2022-Jan-26 11:20:07] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
[2022-Jan-26 11:20:07] [ info] Library loaded, loading member functions.
[2022-Jan-26 11:20:07] [ info] Member functions succesfully loaded.
[2022-Jan-26 11:20:07] [debug] [ Client] - open
[2022-Jan-26 11:20:07] [debug] [ Client] - start
[2022-Jan-26 11:20:07] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence f03f96e9-0e69-49df-bd36-0bd65cc4d9f8.
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2022-Jan-26 11:20:07] [debug] [ JLink] - Logger sink registered in JLink logger
[2022-Jan-26 11:20:07] [debug] [ nRF52] - open
[2022-Jan-26 11:20:07] [debug] [ nRF52] - just_check_family
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - open_dll
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2022-Jan-26 11:20:07] [trace] [ Client] - Command open executed for 2 milliseconds with result 0
[2022-Jan-26 11:20:07] [debug] [ Client] - enum_emu_snr
[2022-Jan-26 11:20:07] [ info] [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.
[2022-Jan-26 11:20:07] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2022-Jan-26 11:20:07] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - dll_version
[2022-Jan-26 11:20:07] [ info] [SeggerBackend] - Segger dll version 7.60.e loaded.
[2022-Jan-26 11:20:07] [trace] [ Worker] - Command open executed for 2 milliseconds with result 0
[2022-Jan-26 11:20:07] [debug] [ nRF52] - enum_emu_con_info
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - enum_emu_con_info
[2022-Jan-26 11:20:07] [trace] [ Client] - Command enum_emu_con_info executed for 94 milliseconds with result 0
[2022-Jan-26 11:20:07] [debug] [ Client] - connect_to_emu_with_snr
[2022-Jan-26 11:20:07] [trace] [ Worker] - Command enum_emu_con_info executed for 94 milliseconds with result 0
[2022-Jan-26 11:20:07] [debug] [ nRF52] - connect_to_emu_with_snr
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - ---just_get_num_emus
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - Segger logging enabled.
[2022-Jan-26 11:20:07] [trace] [ JLink] - Firmware: J-Link V9 compiled May 7 2021 16:26:12
[2022-Jan-26 11:20:07] [trace] [ JLink] - Decompressing FW timestamp took 903 us
[2022-Jan-26 11:20:07] [trace] [ JLink] - Hardware: V9.30
[2022-Jan-26 11:20:07] [trace] [ JLink] - S/N: 269306041
[2022-Jan-26 11:20:07] [trace] [ JLink] - OEM: SEGGER-EDU
[2022-Jan-26 11:20:07] [trace] [ JLink] - Feature(s): FlashBP, GDB
[2022-Jan-26 11:20:07] [trace] [ JLink] - TELNET listener socket opened on port 19021
[2022-Jan-26 11:20:07] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2022-Jan-26 11:20:07] [trace] [ JLink] - WEBSRV Webserver running on local port 19080
[2022-Jan-26 11:20:07] [trace] [ JLink] - - 157.624ms returns "O.K."
[2022-Jan-26 11:20:07] [trace] [ JLink] - JLINK_HasError()
[2022-Jan-26 11:20:07] [trace] [ JLink] - JLINK_Lock()
[2022-Jan-26 11:20:07] [trace] [ JLink] - JLINK_GetHWStatus(...)
[2022-Jan-26 11:20:07] [trace] [ JLink] - - 3.448ms returns 0
[2022-Jan-26 11:20:07] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2022-Jan-26 11:20:07] [trace] [ JLink] - - 0.019ms returns 0x01
[2022-Jan-26 11:20:07] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2022-Jan-26 11:20:07] [trace] [ JLink] - - 0.183ms returns 0x00
[2022-Jan-26 11:20:07] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2022-Jan-26 11:20:07] [trace] [ JLink] - - 0.019ms returns 0x00
[2022-Jan-26 11:20:07] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
[2022-Jan-26 11:20:07] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
[2022-Jan-26 11:20:07] [trace] [ JLink] - - 0.062ms returns 0
[2022-Jan-26 11:20:07] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2022-Jan-26 11:20:07] [trace] [ JLink] - - 18.876ms returns 0x00
[2022-Jan-26 11:20:07] [trace] [ JLink] - JLINK_SetSpeed(2000)
[2022-Jan-26 11:20:07] [trace] [ JLink] - - 5.828ms
[2022-Jan-26 11:20:07] [trace] [ JLink] - JLINK_GetSN()
[2022-Jan-26 11:20:07] [trace] [ JLink] - - 0.030ms returns 269306041
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - read_debug_port_idr
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - read_debug_port_register
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Jan-26 11:20:07] [debug] [SeggerBackend] - coresight_configure
[2022-Jan-26 11:20:07] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 103.693ms returns 0
[2022-Jan-26 11:20:08] [trace] [ JLink] - JLINK_HasError()
[2022-Jan-26 11:20:08] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Jan-26 11:20:08] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2022-Jan-26 11:20:08] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 29.410ms returns -1
[2022-Jan-26 11:20:08] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Jan-26 11:20:08] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Jan-26 11:20:08] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Jan-26 11:20:08] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 2.621ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 2.833ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 2.583ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.941ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 2.889ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.934ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 2.510ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.841ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.809ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 6.500ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.052ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.824ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.535ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 7.645ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.976ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.876ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.786ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 2.884ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.895ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 5.792ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.699ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.985ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 6.828ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.866ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.870ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.151ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 6.523ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 5.600ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.946ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 0.124ms
[2022-Jan-26 11:20:08] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 728 milliseconds with result -102
[2022-Jan-26 11:20:08] [trace] [ Client] - Command connect_to_emu_with_snr executed for 729 milliseconds with result -102
[2022-Jan-26 11:20:08] [debug] [ nRF52] - close
[2022-Jan-26 11:20:08] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Jan-26 11:20:08] [trace] [ JLink] - JLINK_IsOpen()
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 0.021ms returns 0x01
[2022-Jan-26 11:20:08] [trace] [ JLink] - JLINK_Lock()
[2022-Jan-26 11:20:08] [debug] [SeggerBackend] - close
[2022-Jan-26 11:20:08] [debug] [SeggerBackend] - disconnect_from_emu
[2022-Jan-26 11:20:08] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2022-Jan-26 11:20:08] [debug] [SeggerBackend] - is_connected_to_device
[2022-Jan-26 11:20:08] [trace] [ JLink] - JLINK_IsConnected()
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 0.016ms returns FALSE
[2022-Jan-26 11:20:08] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2022-Jan-26 11:20:08] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.403ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.041ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 6.061ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.114ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.360ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 5.064ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 7.259ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 10.804ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 5.934ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.651ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.572ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.882ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 5.539ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 5.462ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 5.654ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.813ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.202ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 2.691ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.795ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 5.095ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.880ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.670ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.040ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.689ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 3.920ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.501ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 6.444ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 4.261ms returns -1
[2022-Jan-26 11:20:08] [trace] [ JLink] - - 0.024ms
[2022-Jan-26 11:20:08] [trace] [ JLink] - JLINK_Close()
[2022-Jan-26 11:20:08] [debug] [SeggerBackend] - Segger Backend closed.
[2022-Jan-26 11:20:08] [debug] [ nRF52] - nRF family DLL closed
[2022-Jan-26 11:20:08] [trace] [ Client] - Command close executed for 172 milliseconds with result 0
[2022-Jan-26 11:20:08] [debug] [ Client] - terminate
[2022-Jan-26 11:20:08] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2022-Jan-26 11:20:08] [trace] [ Worker] - Command close executed for 172 milliseconds with result 0
[2022-Jan-26 11:20:08] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2022-Jan-26 11:20:08] [trace] [ Worker] - Executed 5 commands for 996 milliseconds
[2022-Jan-26 11:20:08] [debug] [ Client] - Worker process exited with code: 0
[2022-Jan-26 11:20:08] [debug] [ Client] - Tried to wait on already ended process: wait error: No child processes
[2022-Jan-26 11:20:08] [debug] [ Client] - Child process terminated with result 0
[2022-Jan-26 11:20:08] [trace] [ Client] - Executed 5 commands for 997 milliseconds
