Issue loading template application in VS Code: wrong CMake kit
Hi everyone.
I'm approacing to the nrf52833 SoC following this  official tutorial but when I import the example template the VSCode finds the cmake tool in my espressif (ESP32) folder, giving an error about its wrong version:
[variant] Loaded new set of variants
[kit] Successfully loaded 9 kits from C:\Users\Andrea\AppData\Local\CMakeTools\cmake-tools-kits.json
[main] Configuring folder: blinky
[proc] Executing command: C:\Users\Andrea\.espressif\tools\cmake\3.16.4\bin\cmake.EXE --no-warn-unused-cli -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=TRUE -Hc:/Users/Andrea/Documents/NordicApps/blinky -Bc:/Users/Andrea/Documents/NordicApps/blinky/build -G "Visual Studio 16 2019" -T host=x64 -A x64
[cmake] Not searching for unused variables given on the command line.
[cmake] CMake Error at CMakeLists.txt:3 (cmake_minimum_required):
[cmake]   CMake 3.20.0 or higher is required.  You are running version 3.16.4
[cmake]
[cmake]
[cmake] -- Configuring incomplete, errors occurred!
It seems the extension doesn't find the ncs toolchain path. How do I fix the issue?
  • Hi Andrea,
    If you close the work space do you have the pop up to select the Zephyr installation ?
    Something like this:
    Please make sure all the plugin/extension has been installed properly.
    Have you tried to edit the  setting of nRF Connect for VS Code extension:
  • If you close the work space do you have the pop up to select the Zephyr installation ?
    No. If I close the workspace/folder that message doesn't appear.
    Today I've unistalled all the Nordic's SDK, Command Line Tool, VS Code extensions, nRF Connect for Desktop, and then I've installed them again following the tutorial I linked above.
    Except for Visial Code that I had already for other my projects with ESP32, Arduino, Flutter and so on...
    I've unistalled the Espressiff extension that was not necessary yet and deleted its references in PATH variable. Now when I create a new nRF project from sample I get
    [main] Unable to determine what CMake generator to use. Please install or configure a preferred generator, or update settings.json, your Kit configuration or PATH variable. Error: No usable generator found.
    [main] Configuring folder: hello_world
    Even if I open the VS Code from Nordic Toolchain Manager.
  • After few months I reinstalled the NCS and now works fine. I suppose due to updates.
