Set Fixed Connection Interval and Event length on Central Side
Hi Nordic people,
I've been working with the s140 for a long time now, having applications with our own central and peripheral device, but so far, the only way to make sure that I control the Connection interval is by setting the MAX and MIN value on the peripheral side to the same value.
Is there a better way to do it on the Central side?
On the central side, on the Connection Event: BLE_GAP_EVT_CONNECTED It's possible to read the suggested values from the current connection.
In order to be able as central, to control this value is to force a sd_ble_gap_conn_param_update() with the same value as max and min.
Is there another way of doing it? The central is the one that decides the connection interval but i don't see any function on the s140 to fix it to ONE specific value.
So far i have seen that a scheduling is not really possible from the programmer perspective, the s140 uses the event length, and similar with the connection interval.
I have an application where i want to connect several peripherals and based on the number of peripherals set a specific event length and connection interval. Is it possible to modify the event length according to our needs at run time?
Any help is welcomed, thank you very much.
SDK17 btw!
