how to dynamically change device_name on NCS?
Hi all:
I want to dynamically change device_name at peripheral_hids_mouse,
I perform two tests, but they are all not successful.
(1)
add below command into prj.conf
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
add below code before bt_le_adv_start()
adv_param.options |= BT_LE_ADV_OPT_USE_NAME;
bt_set_name("test_name");
static void advertising_continue(void)
	struct bt_le_adv_param adv_param;
#if CONFIG_BT_DIRECTED_ADVERTISING
	bt_addr_le_t addr;
	if (!k_msgq_get(&bonds_queue, &addr, K_NO_WAIT)) {
		char addr_buf[BT_ADDR_LE_STR_LEN];
		adv_param = *BT_LE_ADV_CONN_DIR(&addr);
		adv_param.options |= BT_LE_ADV_OPT_DIR_ADDR_RPA;
		int err = bt_le_adv_start(&adv_param, NULL, 0, NULL, 0);
		if (err) {
			printk("Directed advertising failed to start\n");
			return;
		bt_addr_le_to_str(&addr, addr_buf, BT_ADDR_LE_STR_LEN);
		printk("Direct advertising to %s started\n", addr_buf);
	} else
		int err;
		adv_param = *BT_LE_ADV_CONN;
		adv_param.options |= BT_LE_ADV_OPT_ONE_TIME;
        adv_param.options |= BT_LE_ADV_OPT_USE_NAME; //modify
        bt_set_name("test_name");  //modify
		err = bt_le_adv_start(&adv_param, ad, ARRAY_SIZE(ad),
				  sd, ARRAY_SIZE(sd));
		if (err) {
			printk("Advertising failed to start (err %d)\n", err);
			return;
		printk("Regular advertising started\n");
the log shows "Advertising failed to start (err -22)"
(2)
use BT_LE_ADV_CONN_NAME instead of BT_LE_ADV_CONN
adv_param = *BT_LE_ADV_CONN_NAME;
it still show "Advertising failed to start (err -22)"
best regards,
Joe
  • Hi Joe,
    I assume you are not trying to put the name into the Directed Advertising packet but it's the normal advertising you are asking about.
    Please show what's in your ad[] array.
    The following code worked for me:
    	static const struct bt_data ad[] = {
    	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    	//BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    static const struct bt_data sd[] = {
    	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
    	err=bt_set_name("test_name");
    	if (err) {
    		LOG_ERR("Setname failed(err %d)", err);
    		return;
    	err = bt_le_adv_start(BT_LE_ADV_CONN_NAME, ad, ARRAY_SIZE(ad), sd,
    			      ARRAY_SIZE(sd));
    	if (err) {
    		LOG_ERR("Advertising failed to start (err %d)", err);
    		return;
    Note that I have to remove the
    inside the ad[] packet because it's already covered in the advertising option to use name.
    Also if it's already advertising, and you change the name, you need to call
            err = bt_le_adv_update_data( ad, ARRAY_SIZE(ad), sd,
                      ARRAY_SIZE(sd));
    To update the device name.
  • Hi Hung:
    I follow your code,it can update the device name successfully on peripheral_uart example.
    for peripheral_hids_mouse example,
    There are normal advertising and directed advertising,
    I have the error at normal advertising  (Advertising failed to start (err -22)")
    I am not sure the error related to ad[]  /sd[] or not.
        int err = bt_le_adv_start(&adv_param, NULL, 0, NULL, 0);  //Directed Advertising
    } else
    err = bt_le_adv_start(&adv_param, ad, ARRAY_SIZE(ad),      //normal Advertising
    for peripheral_hids_mouse example ,its  ad[] array and sd[] array are not same as peripheral_uart.
    so I don't modify ad[] and sd[] .
    my ad[] array as below
    peripheral_hids_mouse:
    BT_DATA_BYTES(BT_DATA_GAP_APPEARANCE,
                                     (CONFIG_BT_DEVICE_APPEARANCE >> 0) & 0xff,
                                     (CONFIG_BT_DEVICE_APPEARANCE >> 8) & 0xff),
    BT_DATA_BYTES(BT_DATA_UUID16_ALL,
                                      0x12, 0x18, /* HID Service */
                                       0x0f, 0x18), /* Battery Service */
    best regards,
    Joe
  • Hi Joe,
    It's not allowed to have device name in both the advertising packet and the scan response packet.
    So if you already declare adv_param.options |= BT_LE_ADV_OPT_USE_NAME, you should remove BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN) in the scan response.
    Please note that you can step into the function
    bt_le_adv_start() to debug and check what cause the error.
