NRF52832 RTC2
Hi  Nordic:
        We are working on a project, using NRF52832, which has the functions of softdevice+bootloader+ble+dfu, the SDK we use is version 17.0.0,
        and RTC2 is used as a 1ms timer. We found that after running for a period of time, 20 devices A device appears in the RTC2 and cannot generate an interrupt.
       Then we deleted the firmware, using the example of the official RTC2 firmware, the interrupt is also unable to enter, we guessed that there is a problem with the internal crystal oscillator.
        How do we solve this problem
static const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(2);
static uint8_t isSleep = 0;
volatile static uint32_t time_1ms = 0;
#define time_cb_max 32
static TIME_callback time_cb[time_cb_max]={0};
static void rtc_tick_handler(nrf_drv_rtc_int_type_t int_type)
	uint32_t err_code;
    if (int_type == NRF_DRV_RTC_INT_COMPARE0)
//		SEGGER_RTT_printf(0,"1");
//		uint32_t tem1 = NRF_RTC0->COUNTER;
		nrf_drv_rtc_counter_clear(&rtc);
		err_code = nrf_drv_rtc_cc_set(&rtc,NRF_DRV_RTC_INT_COMPARE0,HeartTime_Interval*33,true); APP_ERROR_CHECK(err_code);
		if(isSleep==0){
			time_1ms+=HeartTime_Interval;
			for(int i=0;i<time_cb_max;i++) { //SEGGER_RTT_printf(0,"time_cb[%d]=%d\n",i,time_cb[i]);
				if(time_cb[i]){
					time_cb[i]((uint32_t*)(&time_1ms));
//			uint32_t tem2 = NRF_RTC0->COUNTER;
//			if(tem2<tem1) tem2 += 16777216;
//			if(tem2-tem1>0)	SEGGER_RTT_printf(0,"rtc_tick_handler(%d)\n",tem2-tem1);
    else if (int_type == NRF_DRV_RTC_INT_TICK)
//        SEGGER_RTT_printf(0,"NRF_DRV_RTC_INT_TICK(0x%X)\n",NRF_RTC0->COUNTER);
uint32_t TIME_GetTicks(void)
	return time_1ms;
int TIME_Regist(TIME_callback cb)
		if(time_cb[i]==cb) return -2;
		if(time_cb[i]==0){
			time_cb[i] = cb;  //回调函数
			return 0;
	return -1;
int TIME_UnRegist(TIME_callback cb)
	for(int i=0;i<time_cb_max;i++){
		if(time_cb[i] == cb){
			time_cb[i] = 0;
			return 0;
	return -1;
uint32_t rtc_sleep(uint8_t is_wearshoes)
	uint32_t ret = 0;
	uint32_t err_code;
	isSleep = 1;
	if(is_wearshoes==0){ err_code = nrf_drv_rtc_cc_set(&rtc,0,StandByPower_Interval * 33,true); APP_ERROR_CHECK(err_code);}
	else { err_code = nrf_drv_rtc_cc_set(&rtc,0,LowPower_Interval * 33,true); APP_ERROR_CHECK(err_code);}
	while(nrf_drv_rtc_counter_get(&rtc) != 0);
	for(int i=0;i<5;i++){
		uint32_t cnt1 = NRF_RTC0->COUNTER;
		nrf_pwr_mgmt_run();
//		idle_state_handle();
		uint32_t cnt2 = NRF_RTC0->COUNTER;
		if(cnt2<cnt1) cnt2 += 16777216;
		if(cnt2-cnt1>32) break;
	err_code = nrf_drv_rtc_cc_set(&rtc,0,HeartTime_Interval*33,true); APP_ERROR_CHECK(err_code);
	isSleep = 0;
	ret = (tem2-tem1)/32.768;
	return ret;
static void cb_timeeWakeup(uint32_t t)
	time_1ms += t;
	//SEGGER_RTT_printf(0,"cb_timeeWakeup(%d)\n",time_1ms);
void TIME_Init(void)
	uint32_t err_code;
	nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
	config.interrupt_priority = RTC2_IRQ_PRIORITY;
	config.prescaler = 0;// f(RTC) = 32.768kHZ/(prescaler+1) = 8HZ = 125ms
	err_code = nrf_drv_rtc_init(&rtc, &config, rtc_tick_handler); APP_ERROR_CHECK(err_code);
	nrf_drv_rtc_enable(&rtc);
	Wakeup_Regist(cb_timeeWakeup);
  • Hello ovrebekk
           Thank you very much for your reply. After the RTC error occurred, we tried to burn our own program
    and the official RTC example. There was no assert or some other error, but the RTC just couldn't enter the
    interrupt. At the same time, the board with RTC exception can be used again。
          and we have no way to test your program for the time being. If it comes later, let's test it again
  • Hi Ben
    No problem, just let me know when you have been able to test my example.
    If the interrupt is not firing then the LED will not blink, so it should be very easy to check if the RTC interrupt is OK using that example.
    Best regards
    Torbjørn
  • Hi ovrebekk
         This situation happened again, and I used your example, 283288_rtc_test, the rtc interrupt is still
    unable to enter, all the rtc can't work, it seems that the internal RC crystal is not working properly. This
    board was working before. I burned the rtc after charging, will the temperature damage the internal RC
    crystal oscillator?
  • Hi Ben
    How do you verify that the interrupt is not entering?
    Are you connecting the debugger, or checking if the LED is toggling?
    What is the supply voltage on the chip after you have charged?
    What about during charging, will the supply voltage change?
    crystal oscillator?
    Do you know how high the temperature could get?
    As shown here the nRF52832 should be fine with temperatures up to 125C when it is not in use.
    Could you send me a closeup picture of your board?
    Best regards
    Torbjørn
