Show some services after BLE connection
I would like to resume the discussion made a few days ago in this post.
Is it possible to hide some BLE services until the connection is successful?
I want only my app to see all services. So, after the connection sequence suggested in the previous post, I want to make hidden services visible. it's possible to do it?
Thank you.
  • For a BLE link the connection parameters control the frequency at which data can be exchanged between the peripheral and central once a BLE link has been established between the two. These parameters are negotiated between the central and master during link establishment. Examples of connection parameters are as follows. a. Connection Interval (CI): The central sets the CI when the BLE connection is first established between central and peripheral. The peripheral specifies interval minimum and maximum values, which are the upper and lower limits of the connection interval desired by the peripheral. Most centrals will use some default CI, and will generally ignore the max. and min. numbers specified by the peripheral. The peripheral generally will need to generate a connection parameters update request sometime after the BLE connection is established, to try and change the CI that is within the range. The central will respond with a connection interval that may or may not be in this range. If the peripheral accepts the number, this will be the new CI. b. Slave latency c. Connection supervisory timeout.
  • Hi, I don't understand what all this has to do with my question.
  • Hi Sergi,
    Yes, it's possible to add more services/characteristics in run time. You can take a look here.
    But as mentioned in the case, it's not possible to remove the service after you disconnect. You would need to re-initialize the softdevice to do that. So after a disconnection you need to go through the process to reset the softdevice before you advertise again.
    In my opinion, it's easier that you just limit the functionality when the non-authorized app connected. For example you don't response to a write request. Or don't send the value in a read request. Then you don't need to reset the softdevice in your code.
  • Hi Hung, thanks for your reply
