Is there a way to stop the advertisement from resuming on its own?
Hello.
It is developed using nrf52832 (S132 v7.0.1, SDK v17.0.0) as a peripheral device.
I am implementing the advertisement processing, but the advertisement stops when connecting to the BLE device. However, when you disconnect from the device, the advertisement will start automatically.
I want to prevent advertising from starting on its own.
Do you have any advice?
Best regards.
    Are you using the advertising library?
    If so, the advertising module will resume advertising if the criterias in the on_disconnected and on_terminated functions are met. You could change this by configuring ble_adv_on_disconnect_disabled to true.
    If you are not using the advertising library then the advertising start likely happens as part of the DISCONNECTED event handling.
    Karl
  • Hello.
    I'm using an ad library and when I set ble_adv_on_disconnect_disabled to true, advertising no longer resumes.
    It was very helpful. Thank you very much.
    Best regards.
