Avoid SDK modules who need app timers
I'm developing an application that will run on a board without externel oscillator for RTC1 and it means no app timers support. I started from ANCS example and I see that it uses following modules that needs app timers :
  • BSP for buttons and leds;
  • BLE conn params;
  • scheduler;
What's the suggested why to have above features but without app timers ? Is the scheduler needed ?
Thanks, Paolo
  • Normally with softdevice, you select the LFCLK when you call SOFTDEVICE_HANDLER_INIT
    In your case you call for example
    SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_RC_250_PPM_4000MS_CALIBRATION, NULL);
    Then softdevice will start the LFCLK for your application. If your application does not use softdevice then you can do this in your app like below
    NRF_CLOCK->LFCLKSRC            = (CLOCK_LFCLKSRC_SRC_RC << CLOCK_LFCLKSRC_SRC_Pos);
    NRF_CLOCK->TASKS_LFCLKSTART    = 1;
    while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0)
        // Do nothing.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, NULL);
    And the APP_TIMER will use internal oscillator, you just need to select and start the LFCLK once
  • Hello, what is the softdevice is present but not activated, LFCLK started manually like described above and later SOFTDEVICE_HANDLER_INITis called. Is there any probleme there that the SoftDevice tries to start a clock that is already in use by app_timer?
