PPK2 bricked and firmware update fails
I've was able to use brand new PPK2 to make test measurements few days ago and it was working fine. I've connected the unit today and software have issue recognising the device. I unplugged and plugged PPK2 back into USB and it never turned green, blinking fast red. I've followed instructions to short TP34 and ground. The kit shows up in nRF Connect and I click "Yes" to update firmware but device never comes back. I've tried mac and windows and never was able to successfully update the firmware.
20:29:46.768
Application data folder: /Users/vladimir/Library/Application Support/nrfconnect/pc-nrfconnect-ppk
20:29:50.352
Validating firmware for device with s/n FD8ECA4121AB
20:29:52.760
Error while setting up device FD8ECA4121AB: Error message for known response code from DFU target: Opcode unknown or not supported.
20:29:52.761
Deselecting device
20:29:57.864
20:29:59.136
Error while setting up device FD8ECA4121AB: Error Resource temporarily unavailable Cannot lock port
20:29:59.137
Deselecting device
    Which is the version of the nRF Connect for Desktop and the power profiler version.? Did you download the recently updated versions.? Also, please let me know the version of JLink that you are using.
    Kind Regards,
    Swathy
  • I have old Mac where I use 3.1.3 version with 3.7 version of nRFConnect and I have Windows where I use the latest version. I've tried to update firmware on both with same results. The nRF Connect states the error and device does not light up green.
  • Here is the log from latest 3.9.3 nRF Connect from Windows to update firmware on the device:
    14:42:04.567
    Using @nordicsemiconductor/nrf-device-lib-js version: 0.4.1
    14:42:04.568
    Using nrf-device-lib version: 0.9.8
    14:42:04.568
    Using nrfjprog dll version: 10.15.1
    14:42:04.568
    Using JLink version: 6.88a
    14:42:05.302
    Application data folder: C:\Users\Stas\AppData\Roaming\nrfconnect\pc-nrfconnect-ppk
    14:42:08.280
    14:42:10.141
    Opening serial port for SDFU programming:. 0%
    14:42:10.750
    Opening serial port for SDFU programming:. 100%
    14:42:10.868
    Uploading image through SDFU: 0%
    14:42:11.071
    Uploading image through SDFU: 1%
    14:42:11.090
    Uploading image through SDFU: 2%
    14:42:15.656
    Uploading image through SDFU: 98%
    14:42:15.675
    Uploading image through SDFU: 100%
    14:42:16.387
    All dfu images have been written to the target device
    14:42:26.415
    Error while setting up device FD8ECA4121AB: Error: Timeout while waiting for device FD8ECA4121AB to be attached and enumerated
    14:42:26.415
    Deselecting device
  • Hi Vladimir,
    Sorry for the delayed response. Did you try following the steps mentioned in this ticket.?
    Swathy
  • Swathy, this was first thing I've tried. The firmware updates starts successfully both on Windows and Mac, the led start flashing rapidly during the update but then device goes back to fast blinking red and never turns green. After the firmware update the software reports different problems depending on the version but Windows reports: "Error while setting up device FD8ECA4121AB: Error: Timeout while waiting for device FD8ECA4121AB to be attached and enumerated".
