I am trying to do directed advertising while using the coded PHY whithout bonding the devices but i am running into some problems.
The device with the BT-address i am directing towards (BLE_GAP_ADDR_TYPE_RANDOM_STATIC) does not see/identify the advertising packets meant for it. When i disable directed advertising the device has no problems recognizing the broadcast advertising packets.
I've looked at the advertising packets for both directed and undirected advertising with the nRF Sniffer tool and the only differences i could find where:
- Obviously in directed advertising mode there was a destination address which matches the desired device.
- There was no advertising data in the "AUX_ADV_IND" packet when using directed mode.
The setup has already worked when using directed advertising with the 1M PHY.
I am wondering if i may be missing something obvious or if what i am trying to do is even supported. If it is in fact possible i was wondering if maybe there is an example or code snippet showing the necessary steps to achieve it.
Thanks in advance!
