West does not build a merged.hex or app_update.bin
I am used to using Segger, but am switching to west for various reasons.  The main reason is to create a CI/CD pipeline.
I built a sample project with west, didn't see any errors, but I noticed there is no merged.hex or app_update.bin file produced in the build folder.  I am guessing west does things a bit differently than Segger.  What file should be used for DFU updates, if there is no app_update.bin.  What file should be flashed onto the board using J-Link, if not merged.hex?
chris@Christophers-MacBook-Pro rehab2fit-firmware % west build -b nrf52_r2f_bike_ctrl test/zephyr/samples/boards/nrf/clock_skew
[0/1] Re-running CMake...
Including boilerplate (Zephyr base (cached)): /opt/nordic/ncs/v1.7.1/zephyr/cmake/app/boilerplate.cmake
CMake Deprecation Warning at /opt/nordic/ncs/v1.7.1/zephyr/cmake/app/boilerplate.cmake:37 (cmake_policy):
  The OLD behavior for policy CMP0079 will be removed from a future version
  of CMake.
  The cmake-policies(7) manual explains that the OLD behaviors of all
  policies are deprecated and that a policy should be set to OLD only under
  specific short-term circumstances.  Projects should be ported to the NEW
  behavior and not rely on setting a policy to OLD.
  /opt/nordic/ncs/v1.7.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
  /opt/nordic/ncs/v1.7.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
  CMakeLists.txt:4 (find_package)
-- Application: /Users/chris/Dev/rehab2fit-firmware/test/zephyr/samples/boards/nrf/clock_skew
-- Using NCS Toolchain 1.7.1 for building. (/opt/nordic/ncs/v1.7.1/toolchain/cmake)
-- Zephyr version: 2.6.99 (/opt/nordic/ncs/v1.7.1/zephyr), build: v2.6.99-ncs1-1
-- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
-- Board: nrf52_r2f_bike_ctrl
-- Cache files will be written to: /Users/chris/Library/Caches/zephyr
-- Found dtc: /opt/nordic/ncs/v1.7.1/toolchain/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/opt/nordic/ncs/v1.7.1/toolchain)
-- Found BOARD.dts: /opt/nordic/ncs/v1.7.1/zephyr/boards/arm/nrf52_r2f_bike_ctrl/nrf52_r2f_bike_ctrl.dts
nrf52_r2f_bike_ctrl.dts.pre.tmp:15.39-20.5: Warning (interrupt_provider): /soc/interrupt-controller@e000e100: Missing #address-cells in interrupt provider
  also defined at nrf52_r2f_bike_ctrl.dts.pre.tmp:298.7-300.3
-- Generated zephyr.dts: /Users/chris/Dev/rehab2fit-firmware/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /Users/chris/Dev/rehab2fit-firmware/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /Users/chris/Dev/rehab2fit-firmware/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /Users/chris/Dev/rehab2fit-firmware/build/zephyr/dts.cmake
Parsing /Users/chris/Dev/rehab2fit-firmware/test/zephyr/samples/boards/nrf/clock_skew/Kconfig
Loaded configuration '/opt/nordic/ncs/v1.7.1/zephyr/boards/arm/nrf52_r2f_bike_ctrl/nrf52_r2f_bike_ctrl_defconfig'
Merged configuration '/Users/chris/Dev/rehab2fit-firmware/test/zephyr/samples/boards/nrf/clock_skew/prj.conf'
Configuration saved to '/Users/chris/Dev/rehab2fit-firmware/build/zephyr/.config'
Kconfig header saved to '/Users/chris/Dev/rehab2fit-firmware/build/zephyr/include/generated/autoconf.h'
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/chris/Dev/rehab2fit-firmware/build
[123/130] Linking C executable zephyr/zephyr_prebuilt.elf
[130/130] Linking C executable zephyr/zephyr.elf
Memory region         Used Size  Region Size  %age Used
           FLASH:       38400 B       512 KB      7.32%
            SRAM:        7144 B        64 KB     10.90%
        IDT_LIST:          0 GB         2 KB      0.00%
  • Hello Christopher,
    Does it make any difference if you add a “-p” at the end of the build command?
    west build -b nrf52_r2f_bike_ctrl test/zephyr/samples/boards/nrf/clock_skew -p
    Markus
  • It doesn't.  I am using west as recommended by the Zephyr Project, and zephyr.elf, zephyr.bin, zephyr.hex etc are build, but no merged.hex.  I am not using nrf connect sdk. I am guessing that the sdk helps with this automatically.
    However, I realized I missed a step on the Nordic tutorial:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/mcuboot/readme-zephyr.html
    The step where I am to build a bootloader. The tutorial instructions are a bit sparse.
    Right now I have a board named "my_board" based on nrf52832.  A folder exists in zephyr/boards/arm/my_board with DTS files. Could you help me with the full command?  Do I need to copy that folder somewhere inside the boot folder? The directions have a ".." at the end and I am no expert.  I am stuck at this step.
    To build MCUboot, create a build directory in boot/zephyr, and build it as usual:
    cd boot/zephyr mkdir build && cd build
    cmake -GNinja -DBOARD=<board> .. ninja
    Why aren’t you using the nRF Connect SDK? This is the recommended way to do from our side. Otherwise, you should raise the issue to the Zephyr support.
    Markus
  • I just googled how to build zephyr via command line and I followed some tutorials using west.  I had the nrf connect desktop sdk previously, but I built with Segger.  I didnt know the nrf connect sdk built upon zephyr and added extra tools to make life easier until yesterday. im going to try command line with NCS
