Framing error and noisy data when using UARTE at high baud rate
Hello, in my zephyr application, I have uart1 configured as receive only using uarte at 921600 baud rate. Below is the description node:
&uart1 {
	label = "data_uart";
	current-speed = <921600>;
	status = "okay";
	rx-pin = <30>;
I have a device sending a uart packet every 50ms and although I can see the right number of bytes being received, the data itself is corrupted (some bytes are correct but some are not) and I get a framing error thrown by the IRQ for every packet. I scoped the signal and it is very clean. I have also connected a terminal software (minicom) and I was able to receive the expected data while nrf52833 cannot. I do have another uart running on the same SoC (uart0) and that one is working fine but it is running at 115200 baud rate. I am not sure if I have to do anything special due to the high baud rate. I thought the DMA should help and I have allocated a timer for the byte processing. Here are my config statements:
#uart
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_UART_0_ASYNC=y
CONFIG_UART_0_NRF_HW_ASYNC=y
CONFIG_UART_0_NRF_HW_ASYNC_TIMER=2
CONFIG_UART_0_NRF_ASYNC_LOW_POWER=y
CONFIG_UART_1_ASYNC=y
CONFIG_UART_1_NRF_HW_ASYNC=y
CONFIG_UART_1_NRF_HW_ASYNC_TIMER=4
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM=y
I thought maybe it is a clock issue but my understanding is the system automatically enables the HFCLK. The datasheet mentions a note about the pin drive strength for high baud rate but since I am not transmitting, I don't think this is related to my case. Please let me know if I am missing anything. Thank you.
