I'm trying to build my own "auto sleep" mechanism based on timers.
This is my code:
const nrf_drv_timer_t SLEEP_TIMER = NRF_DRV_TIMER_INSTANCE(2);
int sleep_timer_ms = 10000;
void nrf_timer_init(void) // called from main
uint32_t err_code;
timer_cfg.frequency = NRF_TIMER_FREQ_31250Hz;
timer_cfg.mode = NRF_TIMER_MODE_TIMER;
err_code = nrf_drv_timer_init(&SLEEP_TIMER, &timer_cfg, SLEEP_TIMER_event_handler);
void sleep_timer_reset(void) // varoius user activities trigger this function
nrf_drv_timer_clear(&SLEEP_TIMER);
void sleep_timer_init(void) // called from main (after nrf_timer_init)
int sleep_timer_ticks;
// initiate timer
sleep_timer_ticks = nrf_drv_timer_ms_to_ticks(&SLEEP_TIMER, sleep_timer_ms);
nrf_drv_timer_extended_compare(&SLEEP_TIMER, NRF_TIMER_CC_CHANNEL2, sleep_timer_ticks, NRF_TIMER_SHORT_COMPARE2_STOP_MASK, true);
nrf_drv_timer_enable(&SLEEP_TIMER);
void SLEEP_TIMER_event_handler(nrf_timer_event_t event_type, void* p_context)
soft_sleep();
void soft_sleep(void)
// don't check for errors here. We can get INVALID_STATE - that's ok
err_code = sd_ble_gap_scan_stop(); // <-- program freezes here
NRF_LOG_DEBUG("sd_ble_gap_scan_stop returned %i", err_code);
The timer works as expected, but when the soft_sleep function is reached, the program freezes on the line where I want to stop the scanning:
The same code works properly when I iinitiate the soft_sleep function from a button press. It only fails from the timer handler. How Can i fix it? Thanks.
PS: the timer is enabled anc configured is sdk_config.h
// <e> TIMER_ENABLED - nrf_drv_timer - TIMER periperal driver - legacy layer
#ifndef TIMER_ENABLED
#define TIMER_ENABLED 1
// <o> TIMER_DEFAULT_CONFIG_FREQUENCY - Timer frequency if in Timer mode
// <0=> 16 MHz
// <1=> 8 MHz
// <2=> 4 MHz
// <3=> 2 MHz
// <4=> 1 MHz
// <5=> 500 kHz
// <6=> 250 kHz
// <7=> 125 kHz
// <8=> 62.5 kHz
// <9=> 31.25 kHz
#ifndef TIMER_DEFAULT_CONFIG_FREQUENCY
#define TIMER_DEFAULT_CONFIG_FREQUENCY 0
// <o> TIMER_DEFAULT_CONFIG_MODE - Timer mode or operation
// <0=> Timer
// <1=> Counter
#ifndef TIMER_DEFAULT_CONFIG_MODE
#define TIMER_DEFAULT_CONFIG_MODE 0
// <o> TIMER_DEFAULT_CONFIG_BIT_WIDTH - Timer counter bit width
// <0=> 16 bit
// <1=> 8 bit
// <2=> 24 bit
// <3=> 32 bit
#ifndef TIMER_DEFAULT_CONFIG_BIT_WIDTH
#define TIMER_DEFAULT_CONFIG_BIT_WIDTH 3
// <o> TIMER_DEFAULT_CONFIG_IRQ_PRIORITY - Interrupt priority
// <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef TIMER_DEFAULT_CONFIG_IRQ_PRIORITY
#define TIMER_DEFAULT_CONFIG_IRQ_PRIORITY 2
// <q> TIMER0_ENABLED - Enable TIMER0 instance
#ifndef TIMER0_ENABLED
#define TIMER0_ENABLED 0
// <q> TIMER1_ENABLED - Enable TIMER1 instance
#ifndef TIMER1_ENABLED
#define TIMER1_ENABLED 1
// <q> TIMER2_ENABLED - Enable TIMER2 instance
#ifndef TIMER2_ENABLED
#define TIMER2_ENABLED 1
// <q> TIMER3_ENABLED - Enable TIMER3 instance
#ifndef TIMER3_ENABLED
#define TIMER3_ENABLED 1
// <q> TIMER4_ENABLED - Enable TIMER4 instance
#ifndef TIMER4_ENABLED
#define TIMER4_ENABLED 0
I'm guessing it's the priorities problem (when I change the priority to 7 it works), however I need the timer priority as high as possible, because I use timers 0 and 1 for other, critical things in my app.
