Application won't boot when bootloader and app are using 32kHz RC oscillator. When using MPSL (BLE and IEEE802.15.4 raw) or usb_cdc.
We're having a problem that our application will hang when using the 32 kHz RC oscillator in the mcuboot bootloader and the Zephyr application. We encountered this problem when we updated from NCS 1.5.1 to 1.8.0.
We have looked at https://devzone.nordicsemi.com/f/nordic-q-a/81418/bug-in-ncs-v1-7-1-with-32khz-rc-oscillator-and-mcuboot-enabled and https://github.com/zephyrproject-rtos/zephyr/issues/40538 but that does not seems to fix our issue or is not included in release 1.8.0
In the supplied files is a markdown file with steps how to reproduce the problem.
What could be a temporary fix?
What is the prospect of a permanent fix?
Maarten
rc_oscillator_problem_files.zip
  • Hi Hung,
    - When I run the hex file you provided the application works on both devkits I have without any problems.
    - When I use the example I provided (blinky) without bootloader the application works fine. The issue occurs when we use a different clock configuration for the bootloader and the application. We currently have a bootloader configured with a low frequency clock source: CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH. But it also doesn't work with the default config (CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL). Only when both are set to the _RC oscillator.
    - We have three devkits (myself 2 and my college 1) the behaviour is identical on all three. So your example works and when we compile it, we have the boot problem of the application and it works intermittent.
    For the second part I've tested your configurations and find the same findings as you do.
    The application won't boot when CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_MAX_SKIP=0 is enabled.
    As we currently have a bootloader configured with a low frequency clock source: CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH. As we can't replace the bootloader in the field we are stuck with the current configuration. For MPSL we need to use the CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC in the application as the synthesised clock is not supported.
    What would be a viable path to get to a solution, or do we need to wait until this bug is fixed in the softdevice?
    Maarten
  • Also I won't be available next week so Martijn (my college) will continue responding on this thread next week.
  • Hi Maarten,
    Ok so the MCUBoot is fixed to CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH. This is the new information that hasn't included in the original question or the howtoreproduce.md.
    It would be a challenge to have different RC source between the MCUBoot and the application. I'm checking internally to see if there is any solution.
  • Hi Hung,
    Thank you for checking.
    I agree switching source isn't ideal, and kind of an edge case. However, since we already deployed thousands of units with the bootloader set to the SYNTH clock, we can't really change this.
    This did work perfectly in NCS 1.5, so the hardware does seem to be capable of switching back.
    Martijn Stommels
  • Hi Hung,
    I agree we didn't include the info, we tried to reduce the problem to a simpeler example.
    Do you have any information at this point that could help us?
    Maarten
