nrfjprog Error -"Worker process is dead, cannot execute command" - Ubuntu Docker Container
I am currently trying to get our nRF52 development workflow working in a Docker container. I have been able to compile the firmware in the container and debug it using a remote JLink sever however I am unable to flash the firmware using nrfjprog whilst in the container.
Host: Windows 10
Guest: Ubuntu 20.04 - Dockerfile
When I run (or any nrfjprog command):
nrfjprog -i --log
I get the following error log:
[2022-Jan-31 16:13:56] [ info] --------------------------------------------------------------------------------
[2022-Jan-31 16:13:56] [ info] nrfjprog -i --log
[2022-Jan-31 16:13:56] [ info] nrfjprog version 10.15.2 external
[2022-Jan-31 16:13:56] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
[2022-Jan-31 16:13:56] [ info] Library loaded, loading member functions.
[2022-Jan-31 16:13:56] [ info] Member functions succesfully loaded.
[2022-Jan-31 16:13:56] [debug] [ Client] - open
[2022-Jan-31 16:13:56] [debug] [ Client] - start
[2022-Jan-31 16:13:56] [error] [ Client] - Worker process is dead, cannot execute command.
[2022-Jan-31 16:13:56] [debug] [ Client] - terminate
The error is the same as seen on the nrfjprog not working on raspberry pi 4 post but the solution of "LANGUAGE=en nrfjprog -i" did not work for me.
I was wondering if anyone else has come across this issue and found a solution?
Many thanks,
Archie
  • Had a very similar issue on my Linux machine:
    $ nrfjprog --version --log
    ERROR: [ Client] - Worker process is dead, cannot execute command.
    ERROR: An internal error has occurred, please try again.
    Problem was my LANG env variable, which was set to en_CH.UTF-8, but for which I had no locales generated for. Looks like this in strace:
    openat(AT_FDCWD, "/usr/lib/locale/en_CH.UTF-8/LC_CTYPE", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
    openat(AT_FDCWD, "/usr/lib/locale/en_CH.utf8/LC_CTYPE", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
    openat(AT_FDCWD, "/usr/lib/locale/en_CH/LC_CTYPE", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
    openat(AT_FDCWD, "/usr/lib/locale/en.UTF-8/LC_CTYPE", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
    openat(AT_FDCWD, "/usr/lib/locale/en.utf8/LC_CTYPE", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
    openat(AT_FDCWD, "/usr/lib/locale/en/LC_CTYPE", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
    futex(0x7f60445471e0, FUTEX_WAKE_PRIVATE, 2147483647) = 0
    write(2, "ERROR: [ Client] - Worker proces"..., 67ERROR: [ Client] - Worker process is dead, cannot execute command.
    Worked around the issue by unsetting LANG:
    $ LANG= nrfjprog --version
    nrfjprog version: 10.15.3 external
    JLinkARM.dll version: 7.64c
  • To whoever comes with the same issue.
    It is also $LANG in VS Code.
    There it is set implicitly for integrated terminal.
    Can be changed by
    "terminal.integrated.detectLocale": "off"
    Another thing is that container needs to be run with --privileged
    ("privileged": true in case of devcontainer.json)
