Hello.
I am developing using nrf52832 (S132 v7.0.1, SDK v17.0.0) as a peripheral device.
The program is created by referring to the whitelist of "ble_app_hids_mouse" which is an example of SDK.
At that time, when ble_advertising_start is executed, NRF_ERROR_INVALID_STATE occurs in ble_advertising_whitelist_reply in BLE_ADV_EVT_WHITELIST_REQUEST.
#define BLE_ADV_UUID_SERVICE 0xFFFF
BLE_ADVERTISING_DEF(m_advertising);
// Bluetooth Low Energy UUID type, encapsulates both 16-bit and 128-bit UUIDs.
static ble_uuid_t m_adv_uuids[] =
{BLE_ADV_UUID, BLE_UUID_TYPE_VENDOR_BEGIN},
// Advertising data structure. This structure contains all options and data needed for encoding and setting the advertising data.
static ble_advdata_t m_adv_data =
.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE,
.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]),
.uuids_complete.p_uuids = m_adv_uuids,
// Options for the different advertisement modes.
static ble_adv_modes_config_t m_adv_init =
.ble_adv_whitelist_enabled = true,
.ble_adv_on_disconnect_disabled = true,
.ble_adv_fast_enabled = true,
.ble_adv_fast_interval = APP_ADV_INTERVAL,
.ble_adv_fast_timeout = APP_ADV_DURATION,
// Initialize the advertisement.
ret_code_t err_code;
ble_advertising_init_t adv_init;
memset(&adv_init, 0, sizeof(adv_init));
adv_init.advdata = m_adv_data;
adv_init.config = m_adv_init;
adv_init.evt_handler = on_adv_evt;
err_code = ble_advertising_init(&m_advertising, &adv_init);
return;
// Start advertising.
uint32_t peer_cnt;
peer_cnt = pm_peer_count();
// Determine if there is a bonded device
if (peer_cnt != 0x00) {
// Since there is a bonded device, set the white list.
whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
else {
// Since there are no bonded devices, we will not use the white list in this advertisement.
ble_advertising_restart_without_whitelist(&m_advertising);
err_code = ble_advertising_start(m_advertising, BLE_ADV_MODE_FAST);
return;
// Set a whitelist.
static void whitelist_set(pm_peer_id_list_skip_t skip)
pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
uint32_t peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
err_code = pm_whitelist_set(peer_ids, peer_id_count);
// A function for handling PeerManager events.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id) {
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
if (p_evt->params.peer_data_update_succeeded.data.id == PM_PEER_DATA_ID_BONDING) {
if (p_evt->params.peer_data_update_succeeded.flash_chenged) {
// Advertise event handle.
ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
ble_gap_irk_t whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
uint32_t addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
uint32_t irk_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
switch (ble_adv_evt)
case BLE_ADV_EVT_WHITELIST_REQUEST:
memset(&whitelist_addrs, 0, BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
memset(&whitelist_irks, 0, BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt, whitelist_irks, &irk_cnt);
err_code = ble_advertising_whitelist_reply(&m_advertising_keyless, whitelist_addrs, addr_cnt, whitelist_irks, irk_cnt);
return;
I have ported all the necessary processing, but is there any other necessary processing?
I would appreciate it if you could tell me.
