.bin file of Secure bootloader is too much
I am using nordic52840 development kit board. and I am using sdk17.1 for development.
I tried to create .bin for secure bootloader code inside DFU. but the file size is very large. for my case its around 261MB.
Can any one help me here that why i am getting this much size for binary.
For hex its only 141KB.
Regards
Rohit Saini
  • Actually i am using my won public key and certificate to create a signature on .bin directly.
    And i did as you mentioned by removing the UICR register from hex and then created bin file from hex by using "arm-none-eabi-objcopy" command.
    Now i question. How many ways we can write the data into UICR register..?
    Or anything else we can change here, so that our code directly jump to the Bootloader address..?
    Can you help me here...
    Regards
    Rohit Saini
  • The UICR registers used by the bootloader are only meant to be written once when you first program the device. They cannot be included a DFU image.
    What are you currently using for programming the chip? nrfjprog, jlink commander, or something else? Also, it is a must to use the .bin file for programming, or can you use the .hex?
    Writing UICR with nrfjprog
    > nrfjprog --memwr 0x10001014 --val <bl_start>
    > nrfjprog --memwr 0x10001018 --val <mbr_param_page>
    Vidar
  • I am using nrfjprog only to flash my chip. And also i am using .hex file for programming.
    .bin is only used for creating signature separately.
    But this process will be manually right. First need to build the code then remove the UICR content from the .hex file.
    creating .bin based on that hex file and then i need to create the signature on that bin.
    Is it possible to avoid this much manually intervention..?
    Regards
    Rohit Saini
  • And i have one more doubt.
    LIke i am erasing the flash then loading softdevice code. and then my Blinky application code which started from 0x27000 location in flash.
    nrfjprog.exe --family NRF52 --eraseall
    nrfjprog --program s140_nrf52_7.2.0_softdevice.hex  --family NRF52
    nrfjprog --reset --program blinky_pca10056.hex --family NRF52
    once it reset the LED start Blinking.
    That means its jumping to the 0x27000 memory location. But my question is how he knows that this location it need to jump.
    Because when i did same for the open bootloader code. I created the hex file and i deleted the uicr Address register from hex file and then performed below steps.
    nrfjprog --reset --program open_bootloader_usb_mbr_pca10056.hex --family NRF52
    But in this case its not jumping to my bootloader code. why is that so. why in blibky application its jumping from mbr to its location(0x27000) but for open bootloader code its not jumping to its loaction(0xBE000)....?
    How it knows in case of blink application code and not in Bootloader code...?
    Regards
    Rohit Saini
  • OK, so you should not have to set the UICR registers if your are programming the .hex.
    Yes, and for DFU.
    You will have to decode the intelhex format somehow before you can compute the signature. But this is usually something you will automate through a script (shell, python, etc), so not something you should have to do manually.
    The MBR will jump to the bootloader on startup if it sees the bootloader address at 0x10001014 or 0xff8. Please see the "Master boot record and SoftDevice reset procedure"  section of the Softdevice specification for more details.
    Vidar
