MPSL FEM Support Build Issues on NCS1.7.0
I am having some build issues when attempting to add support for a Skyworks FEM to our application built with NCS 1.7.0 for a NRF52820 target. Our board file is based on the nrf52833dk_nrf52820 board file provided in the SDK.
I have added the following to our proj.conf:
CONFIG_MPSL=y
CONFIG_MPSL_FEM=y
CONFIG_MPSL_FEM_SIMPLE_GPIO=y
I have added the following to our root devicetree node:
     nrf_radio_fem: pa_lna {
         compatible = "skyworks,sky66112-11", "generic-fem-two-ctrl-pins";
         ctx-gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>;
         crx-gpios = <&gpio0 30 GPIO_ACTIVE_HIGH>;
Upon building I get an error in mpsl_fem.c that says: 'mpsl_fem_simple_gpio_interface_config_t' {aka 'struct <anonymous>'} has no member named 'ppi_channels'; did you mean 'dppi_channels'?
Tracing it down it seems that for some reason  #if defined(NRF52_SERIES) is false inside of mpsl_fem_config_simple_gpio.h
Am I doing something wrong with my build configuration or project configuration? Or is there some inherent problem with this SDK version and trying to turn on this feature.
I have modified mpsl_fem_config_simple_gpio.h so that it doesn't check the NRF52_SERIES define. This builds and it seems that the fem is operating as expected. Of course we would like to find a solution to the issue so that we do not need to modify this file.
Thank you
  • Hi Tyler
    This seems like a bug in the code. The NRF52_SERIES define was used in the nRF5 SDK, but will not work in NCS. Instead the CONFIG_SOC_SERIES_NRF52X should be used.
    I will get this confirmed with the software developers, and get back to you.
    Best regards
    Torbjørn
  • Hey Torbjørn,
    Thank you for the info. The strange thing to me is that it seems that the NRF52_SERIES define is true inside of main.c, however in mpsl_fem_config_simple_gpio.h it is false.
    Looking forward to hearing what the software developers have to say about it.
    Tyler
  • Hi Tyler
    According to the developer my earlier response was not correct.
    As long as CONFIG_SOC_NRF52820 is set then the NRF52820_XXAA define should be set here, and if NRF52820_XXAA  is defined then the NRF52_SERIES define should be set here.
    When you say that your board is based on the nrf52833dk_nrf52820 board do you mean that you have created your own board implementation?
    If so, have you ever got this to work with the standard board (using an overlay for the sensor)?
    Would you be able to provide the modified board files?
    Best regards
    Torbjørn
  • Hi Torbjørn
    We did not create our own implementation. We just modified the existing nrf52833dk_nrf52820 board file. I have attached the file here. Again, from what I can tell, NRF52_SERIES is defined inside of main.c, but for some reason it is not defined inside of mpsl_fem_config_simple_gpio.h. Maybe there is some type of linker issue or a file that I have not included that should be. I also can see that CONFIG_SOC_NRF52820 is y and that NRF52820_XXAA is defined in main.c.
    Tyler
    nrf52833dk_nrf52820.zip
  • Hi
    Thanks for sharing the board files.
    I tried to reproduce the issue on my end, but here it seems to build fine, also when accessing the ppi_channels field.
    Could you try to build my project and see if it works OK?
    283704_peripheral_lbs.zip
    It is just a version the peripheral_lbs sample with your configuration added, and the DTS configuration added as an overlay. The sample has to be built using the nrf52833dk_nrf52820 board.
    Best regards
    Torbjørn
