SPI async comms between 2 nRF52dk boards using zephir (nRF Connect SDK v1.8.0)
I have to implement async communication between two nRF52832 chips. I am using two nRF52dk boards and nRF Connect SDK v1.8.0.
Following this case:
https://devzone.nordicsemi.com/f/nordic-q-a/69034/nrf52840-spi-slave-configuration-event_handler
Based on the spi_loopback as suggested on the case, I have managed to get a spi slave sample compiling and working in principle. Here it is the configuration and code:
SLAVE
prj.conf
# Copyright (c) 2020 Nordic Semiconductor ASA
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
# CONFIG_BOARD_ENABLE_CPUNET=y
CONFIG_SPI=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SPI_SLAVE=y
CONFIG_SPI_ASYNC=y
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_PRINTK=y
CONFIG_ASSERT=y
CONFIG_LOG=y
CONFIG_RTT_CONSOLE=y
CONFIG_PRINTK=y
CMakeList.txt
cmake_minimum_required(VERSION 3.8.2)
if (EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/spm.conf")
  set(spm_CONF_FILE
    prj.conf
    ${CMAKE_CURRENT_LIST_DIR}/spm.conf
endif()
if (EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/mcuboot.conf")
  set(mcuboot_CONF_FILE
    prj.conf
    ${CMAKE_CURRENT_LIST_DIR}/mcuboot.conf
endif()
if (EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/${BOARD}.overlay")
  set(mcuboot_DTC_OVERLAY_FILE "${CMAKE_CURRENT_SOURCE_DIR}/${BOARD}.overlay")
endif()
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(03-spis)
target_sources(app PRIVATE src/main.c)
nrf52dk_nrf52832.overlay
&spi1 {
	compatible = "nordic,nrf-spis";
	status = "okay";
	sck-pin = <22>;
	mosi-pin = <23>;
	miso-pin = <24>;
	csn-pin = <25>;
	def-char = <0xFF>;
main.c
* Copyright (c) 2012-2014 Wind River Systems, Inc.
#include <zephyr.h>
#include <sys/printk.h>
#include <drivers/spi.h>
#define DT_DRV_COMPAT nordic_nrf_spis
static const struct spi_config spi_cfg = {
	.operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB | SPI_OP_MODE_SLAVE |
		     SPI_MODE_CPOL | SPI_MODE_CPHA,
	.frequency = 4000000,
	.slave = 1,
const struct device *spi_dev;
#define SPIS_STACK_SIZE 500
#define SPIS_PRIORITY 5
// TODO K_FOREVER should be used in K_THREAD_DEFINE but causes an error
#define K_FOREVER_WORKAROUND -1
extern void spi_test_transceive(void *, void *, void *);
K_THREAD_DEFINE(spis_tid, SPIS_STACK_SIZE, spi_test_transceive, NULL, NULL, NULL,
		SPIS_PRIORITY, 0, K_FOREVER_WORKAROUND);
static void spi_async_call_cb(struct k_poll_event *async_evt,
			      struct k_sem *caller_sem,
			      void *unused);
static struct k_poll_signal async_sig = K_POLL_SIGNAL_INITIALIZER(async_sig);
static struct k_poll_event async_evt =
	K_POLL_EVENT_INITIALIZER(K_POLL_TYPE_SIGNAL,
				 K_POLL_MODE_NOTIFY_ONLY,
				 &async_sig);
static K_SEM_DEFINE(caller, 0, 1);
static int result = 1;
K_THREAD_DEFINE(async_thread, SPIS_STACK_SIZE,(k_thread_entry_t)spi_async_call_cb,
		&async_evt, &caller, NULL, K_PRIO_COOP(7), 0, 0);
static void spi_init(void)
  spi_dev = device_get_binding(DT_LABEL(DT_DRV_INST(0)));
  printk("SPI Init\n");
  printk("Device name: %s\n", DT_LABEL(DT_DRV_INST(0)));
  if (spi_dev == NULL) {
          printk("Could not get %s device\n", DT_LABEL(DT_DRV_INST(0)));
          return;
  printk("SPI CSN %d, MISO %d, MOSI %d, CLK %d\n",
         DT_PROP(DT_DRV_INST(0), csn_pin),
         DT_PROP(DT_DRV_INST(0), miso_pin),
         DT_PROP(DT_DRV_INST(0), mosi_pin),
         DT_PROP(DT_DRV_INST(0), sck_pin));
  k_thread_start(spis_tid);
			      void *unused)
	int ret;
	printk("SPI async callback started\n");
	while (1) {
        printk("Polling...\n");
		ret = k_poll(async_evt, 1, K_FOREVER);
		//zassert_false(ret, "one or more events are not ready");
		result = async_evt->signal->result;
		k_sem_give(caller_sem);
		/* Reinitializing for next call */
		async_evt->signal->signaled = 0U;
		async_evt->state = K_POLL_STATE_NOT_READY;
void spi_test_transceive(void *unused1, void *unused2, void *unused3)
  int ret;
  static uint8_t tx_buffer[32] = { 's', 'p', 'i', 's', 'l',
                                   'a', 'v', 'e', '\n' };
  static uint8_t rx_buffer[32];
  const struct spi_buf tx_buf = { .buf = tx_buffer,
                                  .len = sizeof(tx_buffer) };
  const struct spi_buf_set tx = { .buffers = &tx_buf, .count = 1 };
  struct spi_buf rx_buf = { .buf = rx_buffer,
                            .len = sizeof(rx_buffer) };
  const struct spi_buf_set rx = { .buffers = &rx_buf, .count = 1 };
  printk("SPI Transcive Thread Started\n");
  while (1) {
    ret = spi_transceive_async(spi_dev, &spi_cfg, &tx, &rx, &async_sig);
    if (ret == -ENOTSUP) {
            printk("Not supported");
    if (ret) {
            printk("Code %d", ret);
            //zassert_false(ret, "SPI transceive failed");
    k_sem_take(&caller, K_FOREVER);
    if (result)  {
            printk("Call code %d", ret);
            //zassert_false(result, "SPI transceive failed");
    else {
            printk("byte received: %d\n", ret);
            printk("TX buffer [0]: %x\n", tx_buffer[0]);
            printk("RX buffer [0]: %x\n", rx_buffer[0]);
            tx_buffer[0]++;
void main(void)
    printk("SPIS Example\n");
    spi_init();
MASTER
The problem comes when I tried to implement the master project. First, I implemented the following changes
1. Commented out this line in prj.conf
#CONFIG_SPI_SLAVE=y
2. Changed spi_config to the following:
	.operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB | SPI_OP_MODE_MASTER |
	.slave = 0,
        .cs = NULL
Unfortunately this changes will bring about the below error:
Device name: SPI_1
Could not get SPI_1 device
I tried to follow the comments on this case:
https://devzone.nordicsemi.com/f/nordic-q-a/60878/configuring-spi0---dt_nordic_nrf_spi_spi_0_irq_0_priority-undeclared
but adding any of these lines to prj.conf will cause a cmake error:
CONFIG_SPI_NRFX=y
CONFIG_SPI_0_NRF_SPIM=y
Any help getting a spi async master sample?
Thanks
  • Hi
    Sorry this took some time, I needed to do some digging on my end. You are right, the CONFIG_SPI_1=y was no longer required as of NCS v1.7.0, so it makes sense that v1.8.0 returned this error. I also took the time to test this on my end. Using the SPI_TEST and SPIS_TEST example projects from my colleague Sigurd's Github repo available here. By making some small changes to the prj.conf files and setting the pins to available ones on my DK I was able to get two nRF52840 DKs running an SPI test as expected.
    SPIS prj.conf:
    CONFIG_SPI=y
    # CONFIG_SPI_1=y
    CONFIG_SPI_SLAVE=y
    # CONFIG_SPI_1_OP_MODES=1
    SPI prj.conf:
    # CONFIG_BOARD_ENABLE_CPUNET=n
    CONFIG_SPI=y
    # CONFIG_SPI_0=y
    # UART, SPIM, and I2C are shared peripherals on nrf9160
    # therefore we choose SPI3
    # CONFIG_SPI_1=y
    CONFIG_SPI_NRFX=y
    # CONFIG_DEPRECATED_ZEPHYR_INT_TYPES=y
    Simon
