Hi
I have five custom boards, same batch.
I used one of the boards for developing FW, based on the MQTT simple sample.
The FW uses CA certificates in an h file like the simple sample example.
When i flash the same FW to the four other boards I get:
<inf> mqtt_simple: The MQTT simple sample started <inf> mqtt_simple: Provisioning certificates <err> mqtt_simple: Failed to provision CA certificate: -14 <err> mqtt_simple: Failed to provision certificates
I checked using the Nordic MQTT simple sample and my board
if I run
west build -b <MY_BOARD_NAME>_ns -- -DOVERLAY_CONFIG=overlay-tls.conf && west flash, I get the same error the remaining four boards, but not on my first initial board.
When running
west build -b <MY_BOARD_NAME>_ns && west flash
I get:
<inf> mqtt_simple: The MQTT simple sample started <inf> mqtt_simple: Disabling PSM and eDRX <err> lte_lc: Failed to disable eDRX, error: -8 <inf> mqtt_simple: LTE Link Connecting... <err> lte_lc: Failed to subscribe to CEREG notifications <err> lte_lc: Failed to enable notifications <inf> mqtt_simple: Failed to establish LTE connection: -8 <inf> mqtt_simple: Retrying in 120 seconds,on the four remaining boards, but not on my first initial board.
Before digging deeper into the HW, is there some configuration that I have done on the first board that needs to be set and I have forgot about it?
The FW is exactly the same between the boards, both my own and the Nordic mqtt simple sample.
As a note on three of the boards I also get:
<err> i2c_nrfx_twim: Error on I2C line occurred for message 0 <inf> mqtt_simple: The MQTT simple sample started
I have checked the error codes to this spec: https://docs.zephyrproject.org/apidoc/latest/group__system__errno.html
But it makes no sense on what the errors are about...
Any hints? HW or FW?
/Regards
