Hello
I have been able to run the lvgl sample in the nrf9160dk, however this only works when built in a secure board, when build in non secure a bus fault occurs. Using the addr2line the fault appears in the
Hello
Could you share the full bus fault message?
ssd16xx_init function, while waiting for the!spi_is_ready(&config->bus)
If this is the function that faulted, it could indicate that your device is "NULL". How have you described the device in DTS?
Håkon
I use this overlay to describe the device
&spi3 {
status = "okay";
mosi-pin = <11>;
miso-pin = <12>;
sck-pin = <13>;
cs-gpios = <&gpio0 10 GPIO_ACTIVE_LOW>;
ssd16xxfb@0 {
//compatible = "solomon,ssd16xxfb", "gooddisplay,gdeh0154a07";
compatible = "solomon,ssd16xxfb";
label = "SSD16XX";
spi-max-frequency = <4000000>;
reg = <0>;
height = <200>;
width = <200>;
pp-width-bits = <8>;
pp-height-bits = <16>;
dc-gpios = <&gpio0 9 GPIO_ACTIVE_LOW>; /* D9 */
reset-gpios = <&gpio0 8 GPIO_ACTIVE_LOW>; /* D8 */
busy-gpios = <&gpio0 7 GPIO_ACTIVE_HIGH>; /* D7 */
gdv = [ 00 ];
sdv = [ 41 a8 32 ];
vcom = <0x00>;
border-waveform = <0x05>;
tssv = <0x80>;
st7789v@0 {
compatible = "sitronix,st7789v";
label = "ST7789V";
spi-max-frequency = <20000000>;
reg = <0>;
cmd-data-gpios = <&gpio0 9 GPIO_ACTIVE_LOW>; /* D9 */
width = <240>;
height = <240>;
x-offset = <0>;
y-offset = <0>;
vcom = <0x19>;
gctrl = <0x35>;
vrhs = <0x12>;
vdvs = <0x20>;
mdac = <0x00>;
gamma = <0x01>;
colmod = <0x05>;
lcm = <0x2c>;
porch-param = [ 0c 0c 00 33 33 ];
cmd2en-param = [ 5a 69 02 01 ];
pwctrl1-param = [ a4 a1 ];
pvgam-param = [ D0 04 0D 11 13 2B 3F 54 4C 18 0D 0B 1F 23 ];
nvgam-param = [ D0 04 0C 11 13 2C 3F 44 51 2F 1F 1F 20 23 ];
ram-param = [ 00 F0 ];
rgb-param = [ CD 08 14 ];
I managed to control the device correctly using the nef9160dk_nrf9160 board in the build configuration
This is the configuration
#Display CONFIG_DISPLAY=y CONFIG_DISPLAY_LOG_LEVEL_ERR=y CONFIG_SPI=y CONFIG_SSD16XX=y #LVGL CONFIG_LVGL_DISPLAY_DEV_NAME="SSD16XX" CONFIG_LVGL_HOR_RES_MAX=200 CONFIG_LVGL_VER_RES_MAX=200 CONFIG_LVGL_VDB_SIZE=100 CONFIG_LVGL_DPI=180 CONFIG_LVGL_BITS_PER_PIXEL=1 CONFIG_LVGL_COLOR_DEPTH_1=y CONFIG_LVGL=y CONFIG_LVGL_USE_LABEL=y CONFIG_LVGL_USE_CONT=y CONFIG_LVGL_USE_THEME_MATERIAL=y CONFIG_LVGL_USE_IMG=y CONFIG_LVGL_USE_DEBUG=y CONFIG_LVGL_TXT_ENC_UTF8=y CONFIG_LVGL_FONT_MONTSERRAT_18=y CONFIG_LVGL_THEME_DEFAULT_FONT_NORMAL_MONTSERRAT_18=y
This is the error in the sample "out of the box"
When I tried it in the complete program
Thanks
Could this be the root of the issue?
https://github.com/zephyrproject-rtos/zephyr/commit/5e722c436842068c3ac1d75b440ea505035dfaf6
Could you try to add this workaround (switch the two lines) and see if this helps?
Håkon
