failed to send 8210 bytes over i2c with i2c_write
I use nrf5340 and have issue with i2c large buffer send:
In order to flash page to bootloader with my
application:
  1. I defined
    1. I defined static array with size of 8210
    2. enabled i2c as master
    3. bind i2c successfully(i tested with small buffer size and it is working)
  2. use function i2c_write(i2c_dev, data, size, MAX_ADD);
    1. i2c_dev - a binded device
    2. data - pointer to static buffer
    3. size - 8210
    4. MAX_ADD - device i3c address
I get error from function i2c_write ()   -5 with log  [00:01:48.453,613] <err> i2c_nrfx_twim: Error on I2C line occurred for message 0
ret = k_sem_take(&(get_dev_data(dev)->completion_sync),
				 I2C_TRANSFER_TIMEOUT_MSEC)
the ret value is -11
I need to transmit a full page in one transaction
Thanks for help.
