How to combine the ble_app_uart with libuartes example ?
I have a project that is comunication between nRF and Smartphone via BLE and using libuartes to comunicate with 2 another devices via 2Uarts.
Now I need to combine 2 examples into 1 project. How many stepI have to do ?
I have compared 2 sdk_config.h of 2  examples. there are some differences in 2 sdk_config.h. I think just merge them into one file
What about another files? What I need to combine them and work in 1 project step by step?
Hope your reply soon. Thank you
Best regard,
  • Pham Tam said:
    Can you explain for me the reson why we has to set libuarte's higher interrupt priority than the app_timer.?
    I am not familiar with the details, but I imagine it has to do with the libuarte needs to be able to process interrupts even though you are in an app_timer interrupt.
    Pham Tam said:
    I try to set like that but when I debug I still got the same problem. I don't know why ?
    What problem?
    BR,
    Edvin
  • Since you only have 3 RTCs, and want to use 1 for the softdevice, 1 for the app_timer, you don't have 2 left to use for libuarte. However, if you look at the definition of NRF_LIBUARTE_ASYNC_DEFINE() in nrf_libuarte_async.h, you can see that if you set _rtc1_idx and _timer1_idx to NRF_LIBUARTE_PERIPHERAL_NOT_USED, then it will use the app_timer instead. Try that.
    I got this problem
  • What function returned the err_code that was checked using APP_ERROR_CHECK on l ine 570 in your main.c? And what check inside that function made it return NRF_ERROR_INVALID_PARAM?
    I assume it is related to the initialization of libuarte.
    I used these settings, and it didn't return NRF_ERROR_INVALID_PARAM in my case:
    NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 1, NRF_LIBUARTE_PERIPHERAL_NOT_USED, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
    NRF_LIBUARTE_ASYNC_DEFINE(libuarte2, 1, 2, NRF_LIBUARTE_PERIPHERAL_NOT_USED, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
    static void uart_init(void)
        nrf_libuarte_async_config_t nrf_libuarte_async_config = {
                .tx_pin     = 26,
                .rx_pin     = 8,
                .baudrate   = NRF_UARTE_BAUDRATE_115200,
                .parity     = NRF_UARTE_PARITY_EXCLUDED,
                .hwfc       = NRF_UARTE_HWFC_DISABLED,
                .timeout_us = 100,
                .int_prio   = APP_IRQ_PRIORITY_LOW_MID
            nrf_libuarte_async_config_t nrf_libuarte_async_config2 = {
                .tx_pin     = 6,
                .rx_pin     = 27,
                .timeout_us = 100,
        err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
        ret_code_t err_code2 = nrf_libuarte_async_init(&libuarte2, &nrf_libuarte_async_config2, uart_event_handler2, (void *)&libuarte2);
  • Hi, Edvin now I can use 2 libuartes. But I got a problem
    when I used BLE App send to my nRF a string "hello nrf from mobile phone via ble and libuarte"
    Here is my debug terminal and the result show on Hercules
     But in case I send from my Mobile Phone to nRF a short string like "123456789_123456789". I don't get this problem
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_libuarte_async.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_delay.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "nRF_libUARTE"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 1, 2, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
    NRF_LIBUARTE_ASYNC_DEFINE(libuarte2, 1, 2, 3, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
    //NRF_LIBUARTE_ASYNC_DEFINE(libuarte2, 1, 2,  NRF_LIBUARTE_PERIPHERAL_NOT_USED, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
     NRF_LOG_INFO("call assert_nrf_callback");
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            NRF_LOG_INFO("receieved data from mobile phone");
            NRF_LOG_INFO ("data received: %s",p_evt->params.rx_data.p_data);
            uint8_t uart_string[BLE_NUS_MAX_DATA_LEN+2] = "";
            memcpy(uart_string, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
            uart_string[p_evt->params.rx_data.length] = '\r';
            uart_string[p_evt->params.rx_data.length+1] = '\n';
            nrf_delay_ms(50);
             do
                  err_code = nrf_libuarte_async_tx(&libuarte,uart_string, p_evt->params.rx_data.length + 2);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
        NRF_LOG_INFO("call services_init");
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        NRF_LOG_INFO("call on_conn_params_evt");
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        NRF_LOG_INFO("call slepp_mode_enter");
        // Prepare wakeup buttons.
        uint32_t err_code;
        NRF_LOG_INFO("call on_adv_evt");
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("call BLE_ADV_EVT_FAST");
            case BLE_ADV_EVT_IDLE:
                NRF_LOG_INFO("call BLE_ADV_EVT_IDLE");
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        NRF_LOG_INFO("call ble_stack_init");
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                NRF_LOG_INFO("call bsp_event_disconnect");
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
            NRF_LOG_INFO("call whitelist off");
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
    void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
        nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
        ret_code_t     ret;
        uint16_t index = 0;
        switch (p_evt->type)
            case NRF_LIBUARTE_ASYNC_EVT_ERROR:
            case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
                NRF_LOG_INFO("call rx Data event");
                while (index < p_evt->data.rxtx.length)
                    uint16_t length = (uint16_t)(p_evt->data.rxtx.length - index > BLE_NUS_MAX_DATA_LEN) ? BLE_NUS_MAX_DATA_LEN : p_evt->data.rxtx.length - index;
                    do
                        NRF_LOG_INFO("call after do");
                        ret = ble_nus_data_send(&m_nus, p_evt->data.rxtx.p_data + index, &length, m_conn_handle);
                        if ((ret != NRF_ERROR_INVALID_STATE) &&
                            (ret != NRF_ERROR_RESOURCES) &&
                            (ret != NRF_ERROR_NOT_FOUND))
                            APP_ERROR_CHECK(ret);
                    } while (ret == NRF_ERROR_RESOURCES);
                    index += length;
                nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
            case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
                 NRF_LOG_INFO("call TX done event");
    void uart_event_handler2(void * context, nrf_libuarte_async_evt_t * p_evt)
        ret_code_t     ret;
        uint16_t index = 0;
                NRF_LOG_INFO("call rx Data");
                    do
                    index += length;
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
                .tx_pin     = TX_PIN_NUMBER1,
                .rx_pin     = RX_PIN_NUMBER1,
                .timeout_us = 100,
                .tx_pin     = TX_PIN_NUMBER2,
                .rx_pin     = RX_PIN_NUMBER2,
                .timeout_us = 100,
       // ret_code_t err_code2 = nrf_libuarte_async_init(&libuarte2, &nrf_libuarte_async_config2, uart_event_handler2, (void *)&libuarte2);//edited2
      //  APP_ERROR_CHECK(err_code2);//edited2
        nrf_libuarte_async_enable(&libuarte);
      //  nrf_libuarte_async_enable(&libuarte2);//edited2
        static uint8_t text[] = "ble_app_libUARTE example started.\r\n";
        static uint8_t text_size = sizeof(text);
        err_code = nrf_libuarte_async_tx(&libuarte, text, text_size);
        //err_code2 = nrf_libuarte_async_tx(&libuarte2, text, text_size);//edited2
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
        NRF_LOG_INFO("call advertising start");
    /**@brief Application main function.
        bool erase_bonds;
    log_init();
        // Initialize.
        uart_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Here is my main.c
    Thank Edvin
