After upgrade from nRF Connect SDK 1.4.1 to SDK 1.7.1 we have seen an increase of the current consumption with about 100uA.
Before with SDK 1.4.1 the idle current was about ~60uA, but now we see peaks with about 300uA at about 300Hz (see included picture).
I have tested both with our main application as well with a simple test application (that just initialize all pins then goes into idle).
I have also tested on two different product samples, and the scenario is the same, but the frequency differs from 2.7ms to 3.4ms (290-370Hz).
At this stage we are not using BLE, and the test application just initialize all pins, powers off all external sensors etc and just goes into idle. We just rebuild our applications with the API changes that was needed between 1.4.1 and 1.7.1 so our code is the "same" in both scenarios.
Any ideas why this differs between the two SDK's? Could it be something that we have missed to configure when upgrading from 1.4.1 to 1.7.1 that causes these 300Hz power peaks?
Thomas
