nRF52833 power consumption after upgrade to SDK 1.7.1
After upgrade from nRF Connect SDK 1.4.1 to SDK 1.7.1 we have seen an increase of the current consumption with about 100uA.
Before with SDK 1.4.1 the idle current was about ~60uA, but now we see peaks with about 300uA at about 300Hz (see included picture).
I have tested both with our main application as well with a simple test application (that just initialize all pins then goes into idle).
I have also tested on two different product samples, and the scenario is the same, but the frequency differs from 2.7ms to 3.4ms (290-370Hz).
At this stage we are not using BLE, and the test application just initialize all pins, powers off all external sensors etc and just goes into idle. We just rebuild our applications with the API changes that was needed between 1.4.1 and 1.7.1 so our code is the "same" in both scenarios.
Any ideas why this differs between the two SDK's? Could it be something that we have missed to configure when upgrading from 1.4.1 to 1.7.1 that causes these 300Hz power peaks?
Thomas
  • Hi Simon,
    Yes, I guessed that was the problem, but I don't really know what to do with the information in the commit.
    Again, I use the config (CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION) but I have to disable it (=n) , so I assume that it is not enabled. The other config mentioned in the commit (CLOCK_CONTROL_NRF_FORCE_ALT) is also not user-configurable (get similar compile error should I try to enable it):
    error: CLOCK_CONTROL_NRF_FORCE_ALT (defined at drivers/clock_control/Kconfig.nrf:6) is assigned in a configuration file, but is not directly user-configurable (has no prompt). It gets its value indirectly from other symbols.
    So, I'm left with the setting CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=n and the question if that is correct?
    Is it so that the commit fixes problem in the background, i.e. that disabling the RC_CALIBRATION should work ok?
    Thomas
  • Hi
    I just confirmed that this setting will disable calibration, and is not recommended for longer use as the RC oscillator will likely drift and go imprecise after some time without calibration. Try adding the dependency described here in your project if it isn't already.
    Simon
