Need help with sd-card mounting time
Hello nordic.
I've been using the PPK2 to measure the current draw of the nRF9160DK. However, spi peripherals are not included in these measurements. I was told that if you power the peripherals from nRF_ref they would be but I'm not getting any/the right amount of voltage from those pins. Only the regular VDD ports seem to work. My board is in 3v3 mode.
As the sd-card draws current, I need to be able to either cut power to it when not needing it or dismount it when not needed and mount it when needed.
In the first case, I would like to set a GPIO to 3v3 output and control the pin from software, I have tried this but can't get the gpio to supply the same as VDD pin.
The other solution is to mount the sd card only when needed, the problem with that is that the procedure can take 100-500 ms which causes me to lose important data. Is there an easy way to multithread or use DMA such that I can save sensor data to RAM while the sd-card is being mounted and then, once mounted, I can write directly to it? This is the last bump in the road and I need to solve this, I should mention I tried using the external NOR flash of the nrf9160dk but it was not fast enough for a dataflow of 32kB/s.
So to sum up:
1. I need to measure spi-consumption on the PPK2 but the nRF_ref does not provide the same voltage as VDD
2. I need to be able to turn on and off power to the sd-card which requires a configurable pin. That is, I need a gpio pin with an output equal to VDD
3. Is there a way to run the mounting procedure in parallel with data recording to RAM such that I don't miss data? How?
Thanks beforehand
  • Hi! This is my setup(forgive my paint skills) when using source mode:
    I do have a usb connected to the DK for programming and that would explain the noise. However, can I split the vout from the PPK2 to connect to both nrf_ref on P22 AND supply on P21? If not, would there be a reasonable assumption that the current from ampere mode is the correct one and the added one I get in source mode is due to noise? I should also point out that the ground from PPK2 is connected to the negative terminal on P21.
    Regarding the second part: This would be ideal, however the sd-card mounting procedure takes too much time when it is needed and data is lost. I have created a second ticket for this, thank you very much for your help.
    Edit: When in ampere mode, I have connected it according to the instructions on the PPK2 tutorial video from nordic on youtube.
  • expanded picture for clarity
  • Hi
    You connection diagram looks fine.
    Keep in mind that on the nRF9160DK, there are three chips.
    Debugger
    nRF9160
    nRF52840
    When you measure on the nRF_VDD, you only measure the power consumption of the nRF9160.
    I suggest you stick to ampere mode for measuring.
    Also see Getting started with current measurements on the nRF9160 for some tips.
    Sigurd Hellesvik
  • Why I changed to source mode was to be able to measure the SPI peripherals. If I go back to ampere mode, the peripherals are not included unless supplied by the VDD_nRF but that voltage is not enough to use the peripherals. Can I assume the current draw from perihperals measured from source mode is the same in ampere mode? That is, in source mode, voltage from dk with sensors - voltage from dk = sensor consumption.
    Thank you Sigurd :)
    Yes of course. So you will need to use Source mode.
    Disregard my previous statement, I were confused for a bit since Source and Ampere showed different measurements.
    Then I found that the USB is supplying 5V, while in Source Mode the PPK2 is supplying 3.3V.
    This is the reason for the different current measurements. If you want Ampere mode to measure the same as Source, set the Power of the Source Mode to 5V. Be careful to check if your peripherals can handle 5V.
    So both Source Mode is fine.
    I still would recommend every part one at a time and sum it up once, it will give some more insight and a good double check of things.
    Then you can measure everything at once and know approx what you should get.
    Did this make sense?
    Sigurd hellesvik
