What is the most recent SD and SDK compatibles with REV2 chips?
Hi all,
I would like to know which is the most recent SD and SDK that I should be using with my REV2 chips. In the compatibility matrix, there is no info about the SDK, although it says that the REV2 chips are compatible with softdevice 8. I would assume that if it is compatible with SD8, it would also be compatible with SDK 8... but I am having some uart problems which I also had when trying to use the S130 on a REV2 Chip, so I was wondering if the SDK 8 is not compatible with that revision...
Thanks, Diogo
