GPIOTE library in SDK7.2 with nRF51422
I'm using GPIOTE library to check the change of two switch inputs. Normally it works well, but rarely GPIOTE_IRQHandler become never happen even if the pin level changes. I think the reason is bounds like noise. For example, the pin changes many times while serving this interrupt.
Could you please tell me the solution?
Parents Reply
  • 7.0V is too far from the operating voltage of 3.6V max, but if the noise is spike for few microseconds then I am guessing that it should not damage the line atleast.
    Can you check if the GPIO pin and GPIOTE channel that connected to this pin are operational. You can do this by running GPIOTE example from SDK\examples\peripheral\gpiote and change the code little to match the PIN and GPIOTE channel you used.
    If they are operational, then probably the power spike is taking the module into an unknown state. We cannot do much here inside the chip and you need to solve it by external noise reduction circuits outside the pin.
