BUS FAULT in application code using k_poll
I am using an nRF52833dk to run a simple async SPI transceive API using k_poll
My code is as below, for some reason it always returns BUS FAULT error
Code:
void main(void)
	struct k_poll_signal async_sig;
	uint8_t data = 40, val =0, sz = 9;
	    struct spi_buf bufs = {
            .buf = &data,
            .len = sizeof(data)
    struct spi_buf_set tx = {
        .buffers = &bufs
    tx.count = 1;
	struct spi_buf rbufs = {
            .buf = &val,
            .len = sizeof(val)
    struct spi_buf_set rx = {
        .buffers = &rbufs
 spi_config spi_cfg;
spi_cs_control cs_ctrl;
    cs_ctrl.gpio_dev = device_get_binding("GPIO_0");
    cs_ctrl.gpio_pin = 11;
    cs_ctrl.delay = 0;
    spi_cfg.operation = SPI_WORD_SET(8) | SPI_OP_MODE_MASTER
    //                    | SPI_MODE_CPOL | SPI_MODE_CPHA
                        | SPI_LINES_SINGLE;
    spi_cfg.frequency = 1000000;
	spi_cfg.cs = &cs_ctrl;
	const device * sp;
	sp = device_get_binding("SPI_0");
		data++;
			struct k_poll_event  async_evt =
		K_POLL_EVENT_INITIALIZER(K_POLL_TYPE_SIGNAL,
					 K_POLL_MODE_NOTIFY_ONLY,
					 &async_sig);
			printk("transmitted data: %u \n", data);
			int error = spi_transceive_async(sp,&spi_cfg,&tx, &rx,&async_sig);
			int ret = k_poll(&async_evt, 1, K_MSEC(1000));
			printk("received data: %u \n", val);
Error:
Kindly help to solve this.
Ubaid
  • Could you use addr2line to figure out what line the instruction address 0x0001dfde corresponds to? Follow the instuctions under 3.4 Other tips and tools --> Hard faults, to see how you can do this.
    Simon
  • Hello ,
    I am a little short on time, so rather debugging in detail,
    Can you kindly suggest if this code is the right way to use async SPI API
    Code:
    I have never used k_poll & async APIs before, hence I doubt if it is right.
    Also, is the sequence fine..?
    Within main,
    Post SPI configuration I am calling
    K_POLL_EVENT_INITIALIZER followed by spi_transceive_async() followed by k_poll()
    spi_transceive_async() executes fine, post which I get the bus fault error in the above code.
    Kindly help.
  • It does not look like you have initialized your signal
    static struct k_poll_signal async_sig = K_POLL_SIGNAL_INITIALIZER(async_sig);
  • Hello ,
    Thank you so much,
    I was able to solve that bus fault issue.
    My updated code is:
    #include <string.h>
    #include <errno.h>
    #include <zephyr.h>
    #include <sys/printk.h>
    #include <device.h>
    #include <drivers/spi.h>
    #define STACKSIZE 1024
    #define PRIORITY 99
    void main(void)
                .buf = &data,
                .len = sizeof(data)
            .buffers = &bufs
        tx.count = 1;
                .buf = &val,
                .len = sizeof(val)
            .buffers = &rbufs
    	struct spi_config spi_cfg;
    	struct spi_cs_control cs_ctrl;
        cs_ctrl.delay = 0;
    	spi_cfg.operation = SPI_WORD_SET(8) | SPI_OP_MODE_MASTER | SPI_LINES_SINGLE;
    	const struct device * sp;
    			data++;
    					 &async_sig);
    			int ret = k_poll(&async_evt, 10, K_MSEC(1000));
    And the output is:
     The execution just exists after printing 'r' from the last print statement
    Why isn't it polling at the specified frequency of 1000ms and rather prematurely exiting after one execution.
    Kindly suggest.
  • Hello Susheel Nuguru & Hello ,
    It seems even now the code is throwing faults:
    Please find the sequence of code execution leading to faults as in below:
    kernel.h
    poll.c
    poll.c
    fault_s.S
    fault_s.S
    fault.c
    fault.c
    fault.c
    My code is:
    #include <string.h>
    #include <errno.h>
    #include <zephyr.h>
    #include <device.h>
    #define PRIORITY 99
    void main(void)
                .buf = &data,
                .len = sizeof(data)
            .buffers = &bufs
        tx.count = 1;
                .buf = &val,
                .len = sizeof(val)
            .buffers = &rbufs
        cs_ctrl.delay = 0;
    			data++;
    					 &async_sig);
