I am working on nRF52811 as central and I want to put the device in full power save mode so it does not consume power and activate once I pressed the button. How can I do that?
Thanks!
Thanks!
I suggest to check out for instance the ble_app_hids_keyboard example, where you can find the following implementation:
ret_code_t err_code;
// Prepare wakeup buttons.
}Thanks for the reply.
Actually, I want to add this to the central mode device. Which handler I can use in that case? Can I use P0.26 pin to wake up?
